Samsung un55d6000sf – Bad display or t-Con board?
  • ZRT
    • Sep 2015
    Hi, I'm wondering if someone could point me in the right direction to diagnose my Samsung un55d6000sf before I start throwing money at it. It has like a vertical scroll to it through any input and menus… it starts immediately when the Samsung logo comes up when powered on. No obvious signs on any of the boards as far as bad caps, burnt resistors, fuses etc…
    https://youtu.be/s0y_sa6FSo8
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung un55d6000sf – Bad display or t-Con board?
    Looks like a bad panel or tab bond issue to me.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8158
      I would disconnect one of the ribbon cables from the TCON to the LCD, then the other side.
      • figurehead21
        • Jul 2016
        • 6
        double imaging is 99.9 % panel issue on these samsungs
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          It's generally a panel fault but you could try this quick fix.
          https://www.youtube.com/watch?v=XZ6wjx8IpzM
          • ZRT
            • Sep 2015
            If I unplug the right side of the T-Con the picture clears up on the other side. If I unplug the left, the picture remains scrambled on the opposing side.
            Tried the tape trick and that was a no go.
            So probably a bad display or tab bond issue?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8158
              For me, it's a equal chance between tcon and panel.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
