Panasonic tc-p42s1 dark screen and pink tint.
  • johns1mj
    • May 2015
    • 242
    I just acquired a 09 panasonic tc-p42s1. The screen is dark and the whites have a pink tone. I did not find this on a search of this forum. I have not removed the back of the tv yet. I did a reset of the unit. No its not the common cable box reset.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p42s1 dark screen and pink tint.
    Pictures of the display, maybe SS board fault
    • johns1mj
      • May 2015
      • 242
      I opened up the tv. Looks like someone smoked and blew directly into the fans. everything is coated. I am not the first person into this tv. I found the x-main basically disconnected. I cleaned some contacts and reset some connectors because of the nicotine inside the tv. The panel is now bright again but there are lines across the screen now like a connector not seated correctly. I will have to recheck some connections to see what is happening.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        It does look heavily tarnished with nicotine so a good clean of the boards and connectors would probably be a good idea while you're at it.
        • johns1mj
          • May 2015
          • 242
          Did that. Now i have lines. Will probably need to clean again.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Lines are often but not always as a result of connectors not being reseated correctly so hopefully that's all the problem is.
            • tw2005
              • Oct 2011
              • 6458
              Again no images of the display fault but if horizontal lines commonly improperly seated sd su panel ribbons and the lines will match up with the offending ribbon
              • jimjoe123
                LCD TV Green/Pink screen problem
                by jimjoe123
                I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                Then each time...
                02-23-2020, 01:29 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • Chrissygizmo
                Panasonic TX-48CX350B backlights but white screen , blank screen
                by Chrissygizmo
                Hi all, I’ve got a problem I hope someone can help me fixi.
                I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                01-11-2025, 03:18 PM
              • Alicat
                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                by Alicat
                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                Model number is TH-50PZ85U
                Power comes on and the red power light stays on solid.
                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                I also hear a few clicks.
                I also think my parents said there was a thunderstorm and the TV failed after that.
                Section 6 in the service manual talks about power and no screen,...
                10-30-2024, 10:09 AM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
