While watching tv, our plasma turned off. I turned it back on and noticed the LED power indicator was blinking red...7 times.
I did a little troubleshooting, read, watched some videos and went out and purchased a multi-meter. After testing several connectors, I thought the SC board needed to be replaced.
I replaced the board and fired up the TV. 7 red blinking lights. I then found the technical guide for my TV on this forum. After troubleshooting again, I determined that the SU board was shorted.
At the recommendation of the tech guide, I replaced both the SU and SD boards. I attempted to fire up the TV with the old SC board because I started doubting the SC board was bad in the first place. 7 red blinking lights.
I then installed the new SC, SD, and SU boards and fired up the TV. 7 red lights.
At this point, I am questioning if my multi-meter is working (picked up a Consumer Electronics one at Home Depot for $35) or if the info I read on using it is accurate.
This seems like it should've been a fairly easy repair but I am lost. Can anyone provide any guidance? I will continue to research on this forum and try to make sense of the tech guide. Thanks
