Need bin file for ic 9001 tv pana tc-p50c2
    Hello all.
    Need bin file for ic 9001 tv pana plasma TC-p50c2. I have new CH341A. I want to try it
    Re: Need bin file for ic 9001 tv pana tc-p50c2
    TVRR214AAS
    Panasonic TCP50C2
    Panasonic TC50PX24
    You'd also find these would be ok too
    TVRR214S TVRR214S TVRR214ACS TVRR214ABS
    If you can still get them , only a few bucks
    TVRR214ACS
    https://bestbuy.partsearch.com/Part/...14ACS/New.aspx
    https://www.encompassparts.com/item/.../TVRR214ACS/Ic
    If you're trialling a 1 blink error and you have access to a 42" board, you could save the original file of the 50, copy from the 42 and then write that copy to the 50. If it cleared the fault it would be safe to assume the original was corrupted
      Here's a couple of dumps from a 42" model could be C2, X2 but HD series same board number if you want to play.
      Can't verify if these are corrupted but they are the contents which I copied and then verified matched the chip contents.
      They are of a board someone donated to me which I presume defective.
      IC9304 is the panel address data, don't know what 9001 is.
      My advice is copy, backup and verify first the chip contents you intend to write over just in case you get a bad read from a bad clip connection.
      Also pay attention to the chip type, brand and model etc as one is a 24 , 9304 is a 25 and you will have to plug the lead into the ch341a the right way or it will short.
        Thank you TW2005
        You are so nice . I will try your 42x2 bin for 9001. I will post result. Have good day
          TW2500
          Look like My Ic 9001 is dead. Can not read and write it I will find new one , It is 24C64, Hope I solve problem. I do not know why it is dead.Not corrupted but dead. All data are FF.
            I would check the clip lead continuity as i found them of poor quality and mine broke at the soldered pins in the first few uses
              you also have the option of desoldering the chip and solder it onto the test pad with that programmer if it's the same as mine.
                I did remove the 9001 from the panasonic tv board that has sos1. The ic is bad. programmer does not read and write to this ic.I use the test pad of this programmer.
                  Tw2005
                  Check again It has bad connection at pin 5. I resolder it.
