LG/Optica 7074c / 42" SmartTV
  • Diah
    • Feb 2013
    • 6363
    Re: LG/Optica 7074c / 42" SmartTV
    its android as i thought. so the 2GB SD was extra memory to save data or recording ... any way you need to test yours led one by one with DMM as diode method, you can use 7030 LED Type 6 volts 100 pieces less than 6 USD at aliexpress... but please calculated with finger yours LED are thy 60 or less.. thanks
    • badcaphunter
      • Jan 2016
      • 88
      • England
      8 vr1 - led 51
      7 vr2 - led 41
      6 vr3 - led 31
      5 vr4 - led 21
      4 vr5 - led 11
      3 vr6 - led 1
      2 nc
      1 v - led 60
      LED 14 is lighting a little bit when tested in diode mode
      • Diah
        • Feb 2013
        • 6363
        you need to test them out of the set.. ( not connected to tv ) one by one direct at the LED Pins in opposite probe as diode DMM, they will not lighting up, just they give you the diode Value, which it will be between 740-780, you have some keeping lighting on as you listed before, the test value of them take it as references value to others
        if this test all okay, then the fault not at strips or LEDs.
        • Diah
          • Feb 2013
          • 6363
          doubled
          • badcaphunter
            • Jan 2016
            • 88
            • England
            I'm sure LED 14 is causing the problem, a few look a bit scorched and there seems to be a pattern to it, 14 23 33 43 54 look slightly burnt, Half of LED 14 lights up when tested in diode mode, this is the only LED that does this. Starting at the connector side i get 840 and the max reading is 1050, it seems to increase as i move down the strip, this is testing each diode individually, i have been testing them out of circuit
            • Diah
              • Feb 2013
              • 6363
              himm yours LEDs seem had different way build in Diode, i just took close on yours photo 1 JPG, there is joint pin at the middle of the LED so look at the photo, can you confirm it?
              • badcaphunter
                • Jan 2016
                • 88
                • England
                #27
                i can see it but this does not connect to the board, i think they are soldered under the LED to help with heat dissipation.
                I have attached a datasheet
                  BTW, the pin 1 on the LED connector is the B+ that feed the common ANODE of all the LED strings inside the panel, the VR1~V6 are the CATHODE return for each LED string, so if there is any high impedance or open circuit in the string then you will see very low Voltage on the Vr return pin.
                  And if you look at the Voltage rating of that filter cap for the Boost converter connected to pin 1, you will see that it is only rated at 100V, those LEDs are Dual-LED connected in parallel inside one package
                  (see attached photo), 20 LEDs x 3Vf = 60V for the total VF of one string then + Vdrops on the PWM MOSFETs + current sensing resistor.
                  If the LEDs are dual-LED in series, the you will need 20 x 6Vf =120 V +Vdrops for MOSFETs and Vdrops of current sensing resistor, but as you can see, the Voltage rating of the filter cap is only 100VDC, which BTW, what DCV do you get on that cap?
                  • badcaphunter
                    • Jan 2016
                    • 88
                    • England
                    #29
                    When i power the set on its 23v for a second then goes up to 75v
                    • Diah
                      • Feb 2013
                      • 6363
                      No, yours LEDs wasnt 7030, i just mention them as size and double led 6 volts.
                      i was confused, you should explain that the photo you posted at POST No 9 wasn't belong to yours set, as they have 55 each.. so this why i asked on the No.
                      so you have total 60 with 7 line of socket mean you have 6 groups each 10 and one + common to all groups. but we need to be sure of the zenner Diode of this LED how it built in, Normal LED the Black joint point ( of Zenner ) will be at one side of the LED, you have this POINT at the middle. can you take out the suspected one No 14 out so we will know exactly what we have.
                        That is correct for 100VDC rating cap and for the B+ feeding the LED string anodes.
                        • Diah
                          • Feb 2013
                          • 6363
                          okay, confirmed 7030 innotek from LG. here you can get them
                          http://www.aliexpress.com/item/LG-LE...2-f513c34b6476
                          • badcaphunter
                            • Jan 2016
                            • 88
                            • England
                            #33
                            Thanks for the help guys, i will order the LED's and update in a few weeks, 20-40 days for shipping, i dont want to use anything but the exact parts, not worth the risk with the heat these things put out.
                            • badcaphunter
                              • Jan 2016
                              • 88
                              • England
                              #34
                              I got the LEDs and replaced 6 that looked physically burnt but now when i power the tv on i get a high pitched noise from the inverter board and most of the LEDs go out again.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                have you got all the leds fitted right anode and cathode wise
                                • badcaphunter
                                  • Jan 2016
                                  • 88
                                  • England
                                  #36
                                  yes, i have double and triple checked
                                  • badcaphunter
                                    • Jan 2016
                                    • 88
                                    • England
                                    #37
                                    Every time i test it i'm killing a few LEDs each time, i'm wondering if these are duds or the problem lies somewhere else
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      I wonder if the psu is putting the wrong voltage out and blowing the leds? if this is possible of course and also as you say the leds maybe duds and are not the correct voltage/amps they are stating they are.
                                      • Diah
                                        • Feb 2013
                                        • 6363
                                        the killed one from the old original one. right? get rid of them and replace all at once so you have new strips
                                        • badcaphunter
                                          • Jan 2016
                                          • 88
                                          • England
                                          #40
                                          Problem solved, must have been dodgy LED's or a bad connection. TV is back up and running... after killing 20 LED's
                                          • AstutePauciloquent
                                            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                            by AstutePauciloquent
                                            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                            11-23-2023, 11:02 PM
                                          • survivalbloke
                                            Macbook A2289 - backlight problems - have checked a lot already - out of ideas
                                            by survivalbloke
                                            This is A2289, board 820-01987-A. It came in with the screen not working. We could not see any image on the screen, so we ruled out a backlight issue and instead replaced the panel. The display now comes up, but no backlight.
                                            I didn't see any signs of liquid damage, but there was some odd looking spots around U8400. F8400 has voltage on either side of it, and I have 5v present on R8444 and R8445. I did not have 3.2v at R8442 so I figured U8400 was bad, and I replaced it. After replacement, a brief probe to R8442 showed 3.2v so I assumed I had fixed the device. After reassembly however,...
                                            09-12-2023, 11:44 AM
                                          • letmealone
                                            Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
                                            by letmealone
                                            I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
                                            09-16-2024, 10:03 AM
                                          • kalemaroni
                                            MAG274QRF-QD 27" gaming monitor half backlight shadow
                                            by kalemaroni
                                            A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
                                            04-23-2024, 03:52 PM
                                          • Zilicon
                                            AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                                            by Zilicon
                                            Hearty greetings to everyone, trust you all are doing excellently well.
                                            Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                                            The power stables in very rare case. Once it was stabled, everything works fine.
                                            Once the power switched is pressed, 5V and 3V were present.
                                            The things i have done:
                                            1. I have check for shorts on the board, but nothing. The board is short free
                                            2. Not a power switch problem, it behaves the same without the switch ...
                                            06-10-2024, 05:05 AM
