Samsung UE46D6100 No Power
  • Camshaft
    • Jun 2016
    • 3
    Hi
    I have a Samsung UE46D6100 that does not power up I have read various posts and unplugged power supply cnm803. When unplugged the backlights flash on off on off every second or so. When I plug back in nothing at all is this a clue, what do I try next?
    Cheers
    Cam
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UE46D6100 No Power
    Can you measure the voltage at CNL802 as you switch on.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      So you disconnected the cable from mainboard to the powersupply and turned on the tv?
      Could you use a hairdryer and heat up the power supply for 1/2 mins and turn on the tv? It worked for me with a similar model which told me the PS was bad. Never found out what the problem was as i almost replaced every part haha.
      • CapLeaker
        Leaking Member
        • 8195
        Post all the voltages measured on cnm803 with the corresponding pin out names.
        Could you also give a more detailed description on what the tv does or doesn't do (like status of the LED in front of the tv, etc)? Since the backlights flash, I wonder if there is a bad backlight LED, or something else wrong on the PSU. As mentioned already before, try heating the PSU And retest the backlights.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Back light LEDs issue IMHO.
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mrtek
            Samsung UN43NU6950FXZA No power
            by mrtek
            Hi
            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
            Main fuse = OK
            Back light LED = OK. Power them with aux power source
            LED output = OK 156V
            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
            07-20-2025, 08:06 PM
          • Journey11
            Samsung TV won't turn on ... keeps cycling the power relay on & off
            by Journey11
            Hi All,
            First time posting here ... my name is Kevin but my friends call me Journey.
            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
            07-04-2024, 02:44 PM
