Samsung UN46ES7100F LED power issue
  • tech2014
    • Aug 2014
    • 807
    The tv will work for a long time the when you try and turn off the tv, it won't power off. The only way to power it off is to remove the power cord. Then the power supply clicks a few times, and the tv finally shuts down. The power supply has a lot of transformers on it. I am thinking it is a bad solder joint somewhere. Any ideas? See power supply pic below.
  • Diah
    • Feb 2013
    • 6437
    Re: Samsung UN46ES7100F LED power issue
    you mean wont go to standby with RC and TV side CP. did it do the same if it just power for few second to be on then you try to turn off?
    • tech2014
      • Aug 2014
      • 807
      yes, even after being off for several minutes, if you turn on the tv, then try and turn the power off, it doesn't work. If the tv has been off for a while you can turn it on and the tv will turn off, thats why i think its a p/s issue otherwise I would be a main board problem.
      • Diah
        • Feb 2013
        • 6437
        PWB are servant do exact what main boards order it.. i tip on main boards main processor didn't react on off signal .... check other function on TV sources like HDMI PC or ells, to let it on then tun it off did the same fault
        • tech2014
          • Aug 2014
          • 807
          I reflowed the solder on the p/s and still doing the same thing.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Seems like firmware glitch to me, tried reflashing firmware ?
            • tech2014
              • Aug 2014
              • 807
              So the tv seems ok when you turn the power on/off with the remote. If you remove the power cable from the tv,the standby LED stays on, the samsung logo is lit up, and the power supply relays click, as the red standby LED flashes. I have reflowed the solder on all the major components and also did a firmware upgrade, but it still acts weird.
              Any thoughts??
              • Diah
                • Feb 2013
                • 6437
                once i faced this issue at Toshiba 3D smart TV when i was visit a friend at home, he asked me of issue not powering off when TV stay long time on , i did factory reset it helped for beginning but after play Chanel change with RC it make same issue, changed new RC Batteries then it worked perfect, i think it was the RC send weak signal at other freq. which block the processor . hope this will help you.
                • tech2014
                  • Aug 2014
                  • 807
                  Its worth a shot. I will try it and give an update.
                  • tech2014
                    • Aug 2014
                    • 807
                    no change. Trying to figure out if its a main board issue or p/s
                    • CapLeaker
                      Leaking Member
                      • 8327
                      As for me I agree with Reecey.
                      PSon and BLon come from the main board. So if those are held on, the PSU can't turn off. So verify the DC voltage on the PSon and BLUon pins when you can't turn the TV off. See what gives and report back.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Cheers bud, seems too much like a FW glitch to me.
                        • CapLeaker
                          Leaking Member
                          • 8327
                          Right on, Reecey... We will see what happens to the PSon / Blon signals.
                          • Cookybaby
                            Samsung UN60ES6500FXZA Power Supply Issue
                            by Cookybaby
                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                            Make: Samsung
                            Model: UN60ES6500FXZA
                            Power Supply P/N: BN44-00525A
                            Symptoms: The TV was...
                            08-20-2023, 12:26 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • cheeky2
                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                            by cheeky2
                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                            06-15-2025, 05:12 AM
                          • JimBanville
                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                            by JimBanville
                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                            09-13-2023, 07:21 AM
