LG 42ln578v-ze problems
  • Diah
    • Feb 2013
    • 6435
    Re: LG 42ln578v-ze problems
    you are not going to repair t-con right ? then change it from good source working one.
      You can try new T-CON board.
      You can also check some of the Voltages at these test points:
      VCC
      VDD
      VCC18
      VGH
      VGL
      HVDD
      • jmh474
        • Aug 2016
        • 46
        VCC
        VDD
        VCC18
        VGH
        VGL
        HVDD
        checked voltages this morning, voltages are
        VCC - 3.3v
        VDD - 0v
        VCC18 - 0v
        VGH - 0v
        VGL - 0v
        HVDD - 0v
        • flocko
          • Nov 2012
          • 1121
          Check voltages again this time with the ribbon disconnected that gave you the lines on the screen. see if they come up? but looking like short on the driver board to panel
          • jmh474
            • Aug 2016
            • 46
            ok so checked the t-con card again i was getting the same with both ribbon cables disconnected one at a time but when they are both disconnected i get,
            VCC - 3.3v
            VDD - 15v
            VCC18 - 1.8v
            VGH - 28v
            VGL - 5v
            HVDD - 8v
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              Originally posted by flocko
              check voltages again this time with the ribbon disconnected that gave you the lines on the screen. See if they come up? But looking like short on the driver board to panel
              It does look like there's a panel problem.
              • jmh474
                • Aug 2016
                • 46
                #27
                ok thanks for every ones help, i guess its onto the next one lol
                • flocko
                  • Nov 2012
                  • 1121
                  #28
                  Before you move on take the outside screen surround off, and check driver boards for damage, you could still find a fix.
                  • jmh474
                    • Aug 2016
                    • 46
                    #29
                    ok ill have a look, what sortr of thing am i looking for? iv never gone that deep into a tv befor
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      You need to strip the fram off the Lcd glass whilst being VERY careful, then get us an image of the boards that are bonded to the Lcd screen please.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Also here is a tip if your starting a Tv business, never buy Tv's with lines on the screen and especially Led Tv's with sound, backlight but no Lcd image most of the time its the panel which if thats the case mares well scrap the set as finding a replacement panel is almost impossible and the boards bonded to the screen are actually non serviceable unless you have the right equipment which costs thousands.
                        Can I ask to have you ever fixed a flat panel Tv before this ?
                        • jmh474
                          • Aug 2016
                          • 46
                          #32
                          tv done about 20 tv's just replacing caps, power boards, t-con card im only really just starting to get into it so learning alot.
                          think iv found the problem.....
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            Originally posted by Diah
                            go deep to the panel taps and check if there water damage or burn before you go to change T-CON
                            So that's the problem.
                            • flocko
                              • Nov 2012
                              • 1121
                              #34
                              looks like someone has over done the cleaning of the screen , but all other parts should be good the T.Con tested fine with the ribbons disconnected so the driver board damage was just loading T.Con down. Good luck and keep us updated how you get on with your next repair
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #35
                                Ahh dam panel is done for then common on these, people are not careful when cleaning them
                                • jean luc ferre
                                  laptop hp g72 b52sf screen problems
                                  by jean luc ferre
                                  on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                  the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                  i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                  i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                  06-07-2025, 03:27 PM
                                • Hondaman
                                  USB problems?
                                  by Hondaman
                                  Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                  (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                  I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                  08-12-2024, 03:26 PM
                                • clabr
                                  Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                  by clabr
                                  Need help to solve some problems with this laptop.
                                  After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                  After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                  Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                  Before this had happened I observed some other problems:
                                  When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                  12-02-2021, 08:09 AM
                                • jean luc ferre
                                  display screen problems after changing motherboard
                                  by jean luc ferre
                                  First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                                  I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                                  Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                                  Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                                  09-11-2025, 10:28 AM
                                • rumpumpel1
                                  Lenovo X13-Yoga Gen 1: hibernation problems
                                  by rumpumpel1
                                  I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
                                  11-03-2024, 12:31 AM
