Vizio VW42LFHDTV10A Dies after a few minutes
  • hrabbot
    • Aug 2016
    • 15
    Re: Vizio VW42LFHDTV10A Dies after a few minutes
    Any advice on where I can find the nominal voltages for these ICs? I'm hoping to get this buttoned back up and off the floor of my office. I have a mainboard from a similar model that has all these regulators - should I go ahead and replace any or all of them?
    Thanks much.
    • Kevin Curtin
      • Nov 2016
      • America
      Hello, I have recently been granted with the failure of my Vizio 70 inch smart tv. It's the e701i-A3 (but you already knew that &#128521 well my family and I were watching the football game and *snap* (not any noise) out goes the picture. The light is still on in the back of the tv. When I press buttons on the remote it get brighter then goes dark. Took apart the tv. Back is off and I see 3 boards. T-con, main, and PSU. Question is could I just replace these 3 boards because they are inexpensive or will that not work? Please help me, this TV cost $1,500 and I can't afford a new one .
      • Kevin Curtin
        • Nov 2016
        • America
        That was supposed to say e 7 0 1 I a 3
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          If you could post some clear pictures of the circuit boards.
          The light is still on in the back of the TV. Do you mean the led back lights stay on as seen from the back of the set.
          Can you measure the voltages on the power supply connect going to the main board.
          • hrabbot
            • Aug 2016
            • 15
            Please don't hijack my thread - this issue is unrelated to the issue I'm trying to discuss.
            • hrabbot
              • Aug 2016
              • 15
              More info: I've determined that if the power supply is kept cool with forced air, the TV will never shut off. The heat sink with the mosfet looking guys on it gets very hot otherwise. Does this mean a PS problem, or could it mean another component is drawing too much power and causing PS overheat?
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • howardc64
                Vizio SmartCast TV software bug that looks like hardware
                by howardc64
                Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                11-16-2024, 05:17 PM
