PE0702A, V28A000962A1 (5V Yes, 12V/24V NO)
  • yotsuya
    • Aug 2015
    • 20
    TV: Toshiba 46XV645U
    PSU: PE0702A, V28A000962A1 (purchased used, appeared to been have been previously repaired and lasted 2 years)
    Issues & History:
    - No Power, No Click, No 5V: Tested and found Fuse R851 Open. Replaced R851 and Voltage regulator Q880. A well documented problem and it did bring back some life back to the board because after plugging, the relay engaged and I got 5V but still no 12 or 24V. No red light, nothing happens when power button is pressed.
    - Confused, I obtained a repair kit which replaced a bunch of components. I also replaced the capacitors at c820, c821 as they seemed slightly bulged. End Result: No Difference - same issue.
    Current State: I get 5V. I hear the relay engage. I do not get 12v. I do not get 24V. I do not see a red light. I press power button and nothing happens.
    Pictures provided
    Ideas? Where have I failed?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: PE0702A, V28A000962A1 (5V Yes, 12V/24V NO)
    What voltage do you have on power on pin (P_On, Power ON/OFF) when you come out of standby?
    https://www.youtube.com/watch?v=ttrSsgkI5TE
    • yotsuya
      • Aug 2015
      • 20
      The Voltage I get 3.04V on POW_PRT and 5.5V on POW_SIG , Nothing on POW_TV, 15V AC_DET
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        So you have the following:-
        Pow_Prt 3.04V
        Pow_Sig 5.5V
        Pow_TV 0.0V
        AC_Det 15.0V
        I'm not 100% certain but it looks as though Pow_Prot may be holding the power supply off and not giving the Pow_TV voltage out.
        With the TV powered up what voltage do you have across the two pins of the large capacitors C821 and the one along side it.
        If you disconnect the power supply from the mainboard and switch on what voltages do you have at the output pins of the power supply.
        Have you searched for a schematic for the power supply which would be helpfull.
        • vinceroger69
          • Mar 2012
          • 6714
          the voltage chart provided in this thread post 23 may help
          https://www.badcaps.net/forum/showth...PE0702A&page=2
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            That's interesting in that he cured his problem by reflashing the EEprom.
            If you could provide a similar table as shown in the link above may prove to be usefull.
            Good find VinceRoger69
              https://www.badcaps.net/forum/attach...7&d=1465699555
              You should do the same chart.
              BTW, there must be error on testing, no way you can have 15V on the AC_DET.
              All the measurement are done with meter set to DCV mode. 5.5V on the POW_SIG is alos on the high side when the STBY power supply is only 5.1V.
              • yotsuya
                • Aug 2015
                • 20
                Updated readings - AC_DET was indeed an misread in my previous post. It records 0 (or .01 to be exact).
                The only readings are
                CN90
                POW_TV 3.31
                Pin 13 (5V1) 5.06
                CN91
                POW_PRT 3.04
                AC_DET .01
                The rest are 0 with no changes noted regardless of whether the power button is pressed for any duration.
                  BTW, do you mean R850 the current limiter resistor, not R851 which is not installed. That R850 will go open circuit if the bypass relay SR81 has bad contacts so the resistor is not bypassed when the TV is in full power mode, common failure.
                  So the POW_SIG (PS-ON) is not present?
                  The 'AC_DET .01' should be more than 3VDC for OK, if it is low then it will lock out the PS-ON signal.
                  Pictures provided by SHOPJIMMY.
                  Toshiba 75014973 (PE0702A, V28A000962A1) Power Supply Unit.
                  http://www.shopjimmy.com/toshiba-750...pply-unit.htm#
                  BTW, all the red cylinder fuses are good, right?
                  • yotsuya
                    • Aug 2015
                    • 20
                    Yes, your right R850. That's the fuse that was open and was replaced as well as the voltage regulator at Q880. That brought back some life and the relay SR81 engaged. I also cleaned the relay contacts as part of the initial repair attempt.
                    F895 - I'm getting something odd compared to the other red fuses. My tone is steady on and off, not solid like the other fuses.. Going to investigate after some regular job duties and dinner. Rest of the red fuses are good. i even replaced on from the shopjimmy repair pack.
                    You also correct, POW_SIG (Pin 2, CR91) not present (0 Reading). Yes, an error in my initial post. Readings from post 8 are latest. Apologies for any confusion.
                    • yotsuya
                      • Aug 2015
                      • 20
                      Status: Bad Fuse at F895. Going to replace with a Littelfuse Inc. 37015000000
                      The one below seems to match.
                      http://www.digikey.com/scripts/DkSea...62724773549168
                      Make sense? Should I check anything else beside all my other fuses again?
                      • yotsuya
                        • Aug 2015
                        • 20
                        Well, I'm stumped.
                        I replaced the bad fuse at F895 and now I get AC_DET 3.2, POW_TV 3.31, 5V1 is 5.06 and POW_PRT 3.04. The rest is 0 regardless of power button depressed states.
                        CN90
                        1 GND GND
                        2 GND GND
                        3 18V_Audio w/load 0
                        4 18V_Audio w/load 0
                        5 5_24V w/load 0
                        6 GND GND
                        7 POW_TV 3.31
                        8 GND GND
                        9 12V w/load 0
                        10 12V w/load 0
                        11 12V w/load 0
                        12 GND GND
                        13 5V1 5.06
                        14 GND GND
                        CN91
                        1 POW_PRT 3.04
                        2 POW_SIG 0
                        3 AC_DET 3.2
                        4 POW-LCD 0
                        5 GND GND
                        6 GND GND
                        7 12V_LCD w/load 0
                        8 12V_LCD w/load 0
                        • sibemolll
                          • Aug 2017
                          • 3
                          Hello everyone.
                          I was testing my tv that wasn't even going standby and when I plugged my multimeter in the two external legs of Bridge rectifier, the relays suddenly closed and the TV started working. After turning off the TV and unplugging the energy the tv stopped working and is dead again.
                          What could be causing this problem.???
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            Maybe a bad solder joint or two......
                            Pull it and touch-up all the joints that are screwed to heatsinks.
                            • Badger237
                              • May 2020
                              • 14
                              • United States of America
                              I have this exact board... The problem I found is that the 5V relay (SR81 I believe) gets 5V at the coil ( When I short 5V1 to POW-TV), but doesn't close because there is no current flowing. Where does the circuit for the coil of SR81 go to ground?
                              Also, as of right now I have replaced R850 and do get a steady 5V on 5V1. Finding a service manual has proven impossible. I am an electrical engineering student so I know a thing or two, but I have checked all of the capacitors, diodes, shottky diodes, optocouplers, and I have tested the relay out of circuit.
                              • Badger237
                                • May 2020
                                • 14
                                Also I should add this TV was rendered inoperable by a lighting bolt that hit my chimney and arc'd over to the antenna and continued to destroy every TV in my house that was connected via coax. I'm guessing the main board is toast, but the power board is showing promise after putting in about an hour and 1 dollars worth of parts. If I can prove to myself that the power board works, I plan on confirming the main board is dead and then replacing it.
                                • Badger237
                                  • May 2020
                                  • 14
                                  And, as a third note, it appears that it is actually SR80 rather than SR81
                                    • 12206
                                    • U.S.
                                    Try test #3 below.
                                    Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
                                    • Badger237
                                      • May 2020
                                      • 14
                                      POW-TV has 3.2V
                                      5v1 has 5V
                                      Everything else is Zero
                                      The power button changes nothing.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        One ebay repair kit has the following parts.
                                        Kit Includes - so worth checking those components on the power supply
                                        4pcs FETs (Q820, Q821, Q860, Q861)
                                        1pcs Cement Resistor (upgrade to KOA resistor)
                                        2pcs Resistors
                                        2pcs Fuse
                                        • CuriousJohn
                                          Burco boiler power problem
                                          by CuriousJohn
                                          Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                          Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                          This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                          12-22-2024, 10:25 AM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
