LG 37lg30-ud Screen Has only vertical lines of color?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 37lg30-ud Screen Has only vertical lines of color?
    Fuse marked TK as shown
    • jjzepplin
      • Aug 2014
      • 52
      The side I took off was clear of the lines but the side still connected had the lines. And vise versa when the other side was removed the same thing happened just different sides.
      • jjzepplin
        • Aug 2014
        • 52
        Oh I see it now. So to test- I hook black to ground and and positive to either side of fuse?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          That's correct.
          However it does look like the panel is at fault as suggested earlier.
          • jjzepplin
            • Aug 2014
            • 52
            Same reading both sides of the fuse.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              does sound like a lcd panel fault now you have done all of the tests
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                +1 At this point I must agree.
                • jjzepplin
                  • Aug 2014
                  • 52
                  Good thing I have a really big trash can.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    If the internals are working then put them up for sale.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      yes strip the set down sell or keep the parts even the ccfl tubes come in handy at times people will even buy the stands etc.
                      • jjzepplin
                        • Aug 2014
                        • 52
                        What are ccfl tubes? How do I know the internal are working? Can I feel good about selling on Ebay?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          there the tubes that work the backlight that are behind the lcd screen etc.
                          regarding the boards you can defently sell the psu and invertor board as there working fine the t con and mainboard unless tested in a working tv are harder too test properly.
                          • Stanley1843
                            by Stanley1843
                            06-29-2024, 11:54 AM
                          • Firentiosi
                            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                            by Firentiosi
                            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                            The issues are as follows: the...
                            11-27-2024, 12:33 AM
                          • kca
                            by kca
                            Hello all ~
                            08-31-2025, 06:38 AM
                          • Ancient1
                            Strange LG TV issue : Image vertical lines in black screen
                            by Ancient1
                            Hi
                            Asking for a friend.
                            I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                            but here its the opposite !
                            TV has new T-con = same issue
                            A missing panel voltage would have global effect
                            So , what should one do ? how can I find where the fault is ?
                            Thanks !...
                            02-05-2025, 03:37 PM
                          • Kambi13
                            Samsung LE32C530F1W with vertical lines on Screen
                            by Kambi13
                            Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch...
                            09-15-2022, 07:48 AM
