Panasonic TC-P55VT60 7 Blinks. Need Advice
  • rldev
    • Aug 2016
    • 11
    • US
    I have a Panasonic TC-P55VT60 someone gave me.
    When I first powered on the TV, it did work for a while. I was able to see how many hours(4,000) and firmware, etc. The picture is really good. So I'm determined to get this up and running. Now I never get a picture, just the SOS error codes. I haven't found much in my searches on this particular model in terms of fixit articles and videos. A search on this forum doesn't turn up anything. I do assume it is similar to other models though and they is why I'm seeking some help.
    The TV has the SOS 7 syndrome. After a lot of reading, I assumed it was an SC, SU, SD problem, but that doesn't seem to be the case. I was able to get all three boards for a good price. The boards look good and continuity checks out fine on the SU, SD boards. I'm not sure how to test the SC board, but I have two.
    Anyway, I swapped out all three boards and I still have the SOS 7 problem.
    Here is what I have done:
    1. Replace SU, SD and SC board on the set. Still get SOS 7 error code.
    2. Disconnected the SC board from the SU and SD boards(power and ribbon cable) and turned on the set. Still get SOS 7 error code.
    3. Disconnected the SS board(power and ribbon cable) and turned on the set. I now get an SOS 8 error code.
    I appreciate any help. Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TC-P55VT60 7 Blinks. Need Advice
    Shorted SS possibly, have you a multimeter with diode mode ?
    • rldev
      • Aug 2016
      • 11
      • US
      I have a multi meter with diode option.
      • alexeilb89
        • Jul 2016
        • 10
        I have the exact same problem mine is a TC-P50ST60, picked it up for free to fix.. did all the trouble shooting and replaced the SU,SD,SC boards as suggested in the repair manual. Also checked for short at sc2, sc20, and Vsus.... Let me know if you find anything? I'll be keeping an eye on this thread looking forward to see if you can get yours repaired.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          They give these tv's away for free??? Damn....
          Measure the connector on SS board with and without connected to the powersupply. Measure for short.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            I know. I wish I could get one.
            • tw2005
              • Oct 2011
              • 6458
              Probably worth backprobing the SC2 connector in DC, typical voltage could be 205 -215V so set the meter accordingly. Turn the tV on and see if you see Vsus as it starts up before it trips off.
              Missing Vsus will trigger 7 blink.
              Also if not tried, disconnect the sd/su from the SC, remove the sd/su grounding bolts typcally there are 4. On the SC, locate and short together the 2 pins at SC50, turn the TV on and see if it 7 blinks still.
              • rldev
                • Aug 2016
                • 11
                • US
                Ok it's been a while. I tested sc 50 the 7 blinking lights didn't change. I did see the tiny srv led turn green for a split second and then go dark.
                I can't measure Vsus because the tv doesn't display anything on the screen.
                I have continuity on the y boards. Wierd thing is I used to get a picture at least for a little while now I get nothing. I used two different meters and it appears that there is a power failure as it is only measuring millivolts and low voltage on sd board and the power board.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Its normal that you get low voltage when the tv is blinking.
                  7 blinks is a failure on one of the boards.
                  • rldev
                    • Aug 2016
                    • 11
                    • US
                    Makes sense. I replaced all Y board(3), still 7 blinks.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      You mean you replaced the SC and both buffer boards? EDIT : You already mentioned it in your first post!
                      I think the problem is on the SS board. Disconnect the cable and measure for shorts on the SS board connector.
                      I repaired a 50GT60 this week , image is AMAZING. Much better then my VT50 but i still sold it because of the design......
                      • rldev
                        • Aug 2016
                        • 11
                        • US
                        Sorry you are correct. I will measure the SS board for shorts.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          If you need help how to measure then just say so! We are here to help , im really jealous of you haha.
                          • rldev
                            • Aug 2016
                            • 11
                            • US
                            Yes I DO I pulled the SS board out. There is no doubt that this board was once repaired. I can see solder residue in 4 areas.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Soldering appears to be factory could be residue or board coating that has changed color from heat
                              • rldev
                                • Aug 2016
                                • 11
                                • US
                                Does anyone have any tips for testing the SS board before I purchase one?
                                Does anyone know if there is a difference between tnpa5765 AC (VT series)and a tnpa5765 AH or AB(T series)? I ask because the AH looks almost identical and is more readily available.
                                • rldev
                                  • Aug 2016
                                  • 11
                                  • US
                                  Moreno83 any advice on my last post?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    I'd get the right one. There's a difference in the centre of the board with a bunch of inductors. Shopjimmy has Rev AC in stock anyway.
                                    https://www.shopjimmy.com/panasonic-...s-ss-board.htm
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      It does not matter what kind of Panasonic tv you have. The measurements is the same.
                                      The pictures are from a 50GT50 SS board. They used the 30F132/45F132 mosfets on these boards.
                                      You need to measure EVERY part on the board as i measured on the pictures. Meter in diode/beep mode.
                                      Q = mosfet --> measure outer legs. Beep is bad.
                                      D = diode --> black on middle pin , red on outer legs. ( left and right leg ).
                                      If you measure outer legs on the diode part it will beep.
                                      The SS prong connector MIGHT give a beep for a short periode of time , if it beeps both ways then its shorted. If it beeps for a short period of time and then goes away then it's probably good. Just measure the parts to be sure.
                                      This is for ALL parts on the SC / SS and powersupply.
                                      Hope this helps you a bit on your way
                                      • masa66
                                        • Nov 2021
                                        • Italy
                                        I apologize if I take this thread again ... but in case the failure of the shutdown during the vision, with the 7 flashes and after 2/3 attempts to switch on, it starts to work regularly ... what could it be?
                                        The friend that have open the thread have fix yout tv?
                                        Thank you
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
