Help! My Panasonic TC-P65ZT60 wont turn on!
  • djw43
    • Mar 2015
    • 95
    Re: Help! My Panasonic TC-P65ZT60 wont turn on!
    Originally posted by Moreno83
    Here you go! It's from a friend of mine , he has 2. Suffix sticker might be different.
    https://www.tvonderdelen.nl/detail.p...3%20&language=
    Thank you Moreno83!
    But i am afraid there are to many physical differences for this card to be compatible
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Ok , so the board on the right from shop jimmy is the exact board you need?
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        I can't find the ZT60 board , only the VT60.
        http://www.ebay.com/itm/TNPH1043-TXN...QAAOSw0fhXkoXC
        The ZT60 might have some extra options but the VT60 board should work. There is no different audio system , just speakers connected to the board. Maybe the Vt60 board is bad?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I would reset the VT60 board to its factory settings and see if you get audio back.
          • djw43
            • Mar 2015
            • 95
            Thanks Moreno83, I did update the software, but I can also try to reset to defaults.
            i will also try to output via headphones, external speakers, and blutooth
            • djw43
              • Mar 2015
              • 95
              bluetooth sound does work.and there is a setting to choose bluetooth audio only or all, it was set on BT, but even when set to "All" no sound from internal speakers, not from DVD, HDMI, youtube.
              It is as if it is hard coded to "bluetooth " audio only.
              The VT card does have all 9 of the picture choices , 2 THX modes.
              Has anyone heard of this type of issue?
              thanks
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #27
                Did you reset the board to its factory defaults?
                • djw43
                  • Mar 2015
                  • 95
                  Hi Moreno83, thanks again for all the attention.
                  I did not restore to factory defaults yet, I am worried that I will lose any calibration the OP had set.
                  I guess I could copy the settings down first, that's what I'll do, Thanks!
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    #29
                    Ok , im confused haha.
                    Do you have a zt60 or a vt60? Or do you have a zt60 with a vt mainboard?
                    Yes , write down the settings or simply take some pictures....we all got smartphones haha.
                    • djw43
                      • Mar 2015
                      • 95
                      oh, sorry, yes it is a 65ZT60 but it has a 65VT60 card in it, the ZT card got zapped by lightning.
                      good idea can snap a pic of the settings
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        #31
                        Ok , so you got it calibrated with the VT60 card?
                        Are you sure the speaker cables are connected properly? If the factory reset does not work then you either have bad connection on the mainboard OR the mainboard is defective or the mainboard does not work with the ZT60 speakers.....
                        Last option is probably not the problem , they both have same wattage.
                        • djw43
                          • Mar 2015
                          • 95
                          thanks,
                          yes the speakers are connected properly
                          And when they are disconnected, oddly, i do not get a 12 blink error code.
                          I will reset to factory tonight, and go from there.
                          And i had a speaker from a VT50, and that had no sound either,when i substitued it in, so it is probably the main board
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #33
                            I also think it's the mainboard. In this case factory defaults dont matter because a new mainboard will come with same default settings...
                            Good luck!
                            • budwich
                              • Jul 2015
                              • 3097
                              Some questions... does the set have "sub audio / amp" boards for driving the internal speakers? If so, do you know if they did / did not get "zap" along with the main? What signal source are you verifying the sound with? I haven't seen any "internal / external" choices in a quick scan of owners manual... but maybe it is there somewhere.
                              • djw43
                                • Mar 2015
                                • 95
                                Hi budwich
                                for internal sound source there is a flowery test page you access from self-test,
                                it notes you should see a picture and hear music. (no audio)
                                Also somewhat internal, NETFLIX and Youtube
                                for external input, I tried the RCA jacks for AV input from a DVD player. (no audio)
                                also each HDMI input from cable box output.
                                There isn't any hardware between the "A" board and the speakers.
                                And this is a replacement "A" board, it did not get zapped, in case there is some amping in line.
                                I am leaning more towards bad "A" board rather than compatibility issue.
                                I will have a 65ZT60 card to try within a week, and that should confirm that its the VT card, or I don't know what else.
                                But planning on reverting to factory defaults tonight.
                                thanks for the help!
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  ok... thanks for the extra info. :-( have you tried any of the digital audio outs?
                                  I guess one other question is what is your speaker control set to? :-)
                                  • djw43
                                    • Mar 2015
                                    • 95
                                    No, I have not tried digital audio out, I will check the manual to do that, goid idea.
                                    And yes , speaker level is adaquate
                                    Thnx!
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      ok... but I am not talking about "speaker level"... I am talking about "speaker control"... :-) I seem to recall lots of discussion about pany "screwing" this up.... maybe yours isn't set right. When you go into the sound "settings", what options are you seeing?
                                      • djw43
                                        • Mar 2015
                                        • 95
                                        Oh ok, I have the setting on auto detect to determine if ext speakers are connected. And in the bluetooth setting I have "All" selected for both bluetooth and normal simultaneously
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          hmmm... not quite what I am thinking.... under what "tab" is the "auto detect" and what other options are there in that "sub tab"?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
