HELP!!! LG 50PN4500 plasma. Voltage issue.
  • Mel0317
    • Jul 2016
    • 6
    I am having an issue with z sustain board. The T.V. doesn't want to turn on. I tracked it down to a problem with the z sustain board but I am having issues finding which component is bad.
    The high voltage going from z to y is good but there is 17 volts that goes to y that only reads 3 volts. I have pulled all electrolytic and all brown film capacitors and tested them with a capacitance meter. And all are well within tolerances.
    Any ideas on where to go now? I would much rather replace a component than replace the whole board.
  • Hamie
    • Apr 2014
    • 1383
    Re: HELP!!! LG 50PN4500 plasma. Voltage issue.
    You probably have a faulty y-sustain.
    YSUS needs to be working perfectly for voltages to be accurate on this model. Took me hours to work out what was wrong with the several dozen of these and similar models that share this YSUS.
    Take a picture of your YSUS.
    • Mel0317
      • Jul 2016
      • 6
      I'm not sure if the image is going to post. But the ysus is good. It is brand new. I replaced it before I did any voltage testing. The pin from the xsus that is supposed to carry +17v to the ysus is only putting out 3 volts. And there is a jumper further down the zsus that is labeled 18v that only puts out 3. And I know there isn't a problem with the power supply board because all voltages leaving the power supply are perfect.
      • Hamie
        • Apr 2014
        • 1383
        Put you meter in ohm.
        Under the 2.2 ohm resistor (red red gold gold) you'll find a surface mount cap.
        Test it, if its shorted it needs to be replaced. I used a 22nf
        As a replacment.
        Let us know how you get on.
        • Logen1
          • Mar 2017
          • 32
          Mel0317
          Did you end up resolving this issue? I have an LG 50PN4500 that has the same voltage coming from ZSus as yours did and my logic board has no lit led on it either. I was leaning towards a new main board? I am going to check the surface mount cap under the resistor in the morning as it is late here. Let me know thanks.
          • Logen1
            • Mar 2017
            • 32
            I was curious where on the tv and which board this picture is of Thanks for your time
            • Logen1
              • Mar 2017
              • 32
              Mel0317
              Does your YSus have a ticking noise coming from the area on the bottom right where the yellow transformer is?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Post #3 has the picture of the circuit board and Hamie has referenced the 3 resistors grouped together in his post and said check capacitor underneath the red, red, gold, gold resistor.
                • Logen1
                  • Mar 2017
                  • 32
                  The power supply is showing a short on the VSTP where it should be reading 205V the VATP is reading 55V which is the right voltage. I believe the problem is my power supply, when I disconnect the Y Sus I have audio but no picture, when I diss connect the ZSus it disconnects the YSus at the same time, I still have audio with no picture. If I leave all boards connected then I still have normal on/off and audio with no image. Should I test this IC under thes resistors or is it on the underside of the board? If so how do I detach the ribbon cables safely? Thanks for your time.
                  • Logen1
                    • Mar 2017
                    • 32
                    This is the location of the clicking noise.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Have you checked the capacitor as suggested by Hamie?
                      You can check the Q202, D202, D206 without removing the board. Use your meter set to diode mode and ensure that the set is powered down and disconnected from the wall socket.
                      • Logen1
                        • Mar 2017
                        • 32
                        Q201=513
                        D202=515
                        D203=526
                        D204=521
                        D205=523
                        D206=486
                        Should I replace D206? Or is it withing tolerable limits? I think it might be my power supply? When I diss connect the Z & Y Sustain boards my VS is still shorting on the pin out to the Z Sus? I am new to this. I am not sure if "Hamie meant that the Y and Z Sus need to be connected in order for the power supply to have proper voltages?
                        • Logen1
                          • Mar 2017
                          • 32
                          Please let me know thanks
                          • Logen1
                            • Mar 2017
                            • 32
                            Ok first picture is of PSB to Main board, second pic is of test results not sure if the voltages are to spec or not? Curious though when I test the VS on the two pins in the 3rd picture and they short when the black probe is attached to the chassis, but when I touch the black lead to either one of the two heat sinks on the left I get a voltage from the VS PINS (pic 3) in the 20 to 30 volt range fluctuating.
                            • Logen1
                              • Mar 2017
                              • 32
                              First pic
                              • Logen1
                                • Mar 2017
                                • 32
                                2nd pic
                                • Logen1
                                  • Mar 2017
                                  • 32
                                  3rd pic
                                  • Logen1
                                    • Mar 2017
                                    • 32
                                    4th pic. I am not entirely sure why I couldn't upload more then one pic per post but I suppose it's ok.
                                    • Logen1
                                      • Mar 2017
                                      • 32
                                      Ttt
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        When u go to manage attachment and you click on attach then click attach again under the first one u clicked and attached with and keep on going...
                                        • bajdik
                                          Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                                          by bajdik
                                          I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                                          Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                                          I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                                          Unfortunately, I don’t have access to the schematic.
                                          It seems to me that when I bend the board, something changes.
                                          Could this...
                                          Yesterday, 07:26 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          by sam_sam_sam
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                        • Use2bavolvo
                                          Magic chef oven - thermistor ref voltage issue
                                          by Use2bavolvo
                                          I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                                          Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                                          01-19-2023, 01:32 AM
                                        • cagri
                                          BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                                          by cagri
                                          I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                                          PMIC: iML8940
                                          There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                                          Input 12v, fuse ok
                                          DVDD1V2 = 1.2v
                                          DVDD1V8 = 1.8v
                                          DVDD3V3 = 3.3v
                                          VGL = -7v
                                          **VGH = -0.3v
                                          **VCOM0, AVDD, HAVDD = 0v
                                          SWBK1 = 3.3v
                                          SW1 = 12v
                                          VGH to GND resistance is 500kohm as expected
                                          Readings are same after I disconnected the two cables from TCON to panel...
                                          07-27-2023, 09:48 PM
