LG 50PB2DR help running extra fans
  • Tommy2shoes
    • Oct 2014
    • 44
    Hi Fellas was hoping to some advice on running extra fans to cool heatsink. which pins would be best .I found and tried 12v and ground but seems to either stay on continuously or nothing. Have read a few posts of some of the Lads having done this but cant something like a how to.Any advice would be a God send. Cheers
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: LG 50PB2DR help running extra fans
    I know you probably want to reduce the heat on then heatsinks ,but hot to touch is not hot for semiconductors
    I would not bother , mounting the fans will be a big issue and the noise
    • Tommy2shoes
      • Oct 2014
      • 44
      Hi Chris thats the funny thing it hardly gets warm and yet after 10/15 minutes the sound goes it was only when I put a fan over the ysus that it ran all day. Fans are only 5x5 cm pulling those chips and heat sinks can be quite the task and worry about being up for the whole board, read a good article on here about heating the whole board up to 100 dgs in oven then using wick. Anybody else can point the way by all means feel free
      • chrismurphy
        • May 2014
        • 251
        • australia
        Please do not and I mean DO NOT put boards in the oven ,YouTube posters should be shot for this. IT DOES NOT WORK and will damage components
        Look for the issue by getting some freeze spray and locate the issue on the main board. The y-sus is not your issue for sound , the sound comes from the main board.
        Get your freeze spray and target areas of the board until you narrow down the area ,then target individual components until you find the culprit , then replace the faulty component
        • Tommy2shoes
          • Oct 2014
          • 44
          Hey Chris check out Equipment Usage,Soldering,Techniques and Reviews.
          Third page. Title; Desoldering Trouble , Pad Repair Questions. I think it makes sense and a technique worth considering especially if damage to pads and tracks through prolonged periods of heat at a singe point is the main issue. The board and components reach a peak of 200+ degrees while travelling through the reflow oven ( worked as a SMT, programming component placement and producing populated boards) and By starting with an overall constant temperature of say 100 dgs you would reduce the rate of which the temperature in the tip takes to heat and reach liquidity on the solder joint and the time taken for the tip to return to its temperature setting and maintain a soluble joint . Definitely a method worth considering when others have failed. Thanks heaps for your input of possible main board being trouble area. I am still learning the basic steps to follow and was concentrated on z-sustain/y-sustain boards following Toms steps in plasma trouble shooting reference guide of sound/ no sound. Still find it hard to go past the issue of sound there to begin with then goes missing and with just a cheap oscillating fan pointed at z-sustain all works fine and the sensing minimal heat come off that chips heatsink that its not the heatsink compound that needs to be reapplied. Once again sincere thanks for your input and will apply the process you suggested .
          • chrismurphy
            • May 2014
            • 251
            • australia
            Ok but some components are not passed through ovens they are added after and wave soldered , but i dont want to argue
            Replace the main board or and the faulty component
            Putting it in the oven will destroy the board connectors and capacitors , but go ahead ,seems you have made up your mind and dont want to listen to informed advice
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
              Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-07-2024, 06:21 AM
            • b-slayer
              Asus Strix-G15-G513RM fans don't work
              by b-slayer
              I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
              The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
              (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
              (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
              ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
              09-04-2025, 04:58 AM
            • Rudolfl
              Clevo PC70DP issues
              by Rudolfl
              Hi all
              I have one of those machines. Clevo PC70DP.
              Machine starts, but turns off quite quick. Just before turning off one can hear fans are spinning at high speed. Can be turned back on again right away.
              So, feels like overheat problem.
              I cleaned up fans and heatsinks and replaced thermal paste. I can now see CPU runs cooler and machine stays on for longer, but still same.
              Few more findings:
              1. on-board NVIDIA card is not found. Not showing up in Windows or in BIOS.
              2. I tried to run CPU stress test. CPU stays at about 65 degrees. Works...
              07-16-2025, 01:43 AM
