Technika 40" LCD -- Back into Standby
  • TheBookmark
    • Jul 2016
    • 3
    • Scotland
    Hey Folks.
    My dads Technika is having some issues. When coming out of standby the blue standby light goes off as normal and the screen comes on for about 2 seconds before turning back off into standby mode.
    Much to my puzzlement I have replaced both the power supply board and mainboard, and still have the same issue. The parts were cheap and I can probably re-sell on ebay quickly, at least.
    Could it be the inverter? I thought that would manifest itself in image distortions rather than a power on-off cycle, but what do I know!
    Your ideas would be much appreciated.
    I don't have the TV with me so I made this diagram of the backside of the TV and the parts it uses.
  • culcuhain
    • May 2016
    • 186
    • U$@
    Re: Technika 40" LCD -- Back into Standby
    I would look at your inverter is all the boards check out.
    • vinceroger69
      • Mar 2012
      • 6714
      this could be a faulty inverter transformer or a faulty ccfl tube maybe start with testing the transformer windings what the part number from the transformer
        Another one of those SSI400WA16 inverter board.
        Samsung LJ97-00998A (SSI400WA16) Backlight Inverter
        reece has good info on that repair.
        https://www.badcaps.net/forum/showthread.php?t=40705
        I would disconnect the cable to the inverter board to see if the TV will stay on with input signal.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          +1 lol cheers bud
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ive serviced a few of this chassis, they are so bulky and massive for an Lcd ! Also do what bud says and disconnect the inverter see if the set comes on with no backlight. Also Id advise you keep all the other parts as the Psus on these Ive seen a few blow up as the inverter uses alot of juice 200w into it to be exact then 70-90 for the rest of the parts !
            • TheBookmark
              • Jul 2016
              • 3
              • Scotland
              Thanks for all the pointers and help guys, what a great community.
              Tomorrow, when I go look at the TV again I'll try removing the ribbon cable on the inverter and see whether it stays powered up. I'll let you know the results. Currently following the rabbit hole of links regarding this inverter, and enjoying it more than I should.
              • vinceroger69
                • Mar 2012
                • 6714
                wrong thread please ignore
                • Chrissygizmo
                  • Mar 2021
                  • 108
                  • United Kingdom
                  I know this is an ancient thread but I've just found that removing the button board on a technika 39 c273 solved the same problem, haven't a clue why but as soon as I plug it back in again the tv starts turning off/on
                  • lotas
                    • Jan 2016
                    • 4468
                    • Russia
                    This means that one or more buttons have internal resistance (leakage), change all the buttons on the board and solve the problem.
                    • Chrissygizmo
                      • Mar 2021
                      • 108
                      • United Kingdom
                      I tested all buttons with a multimeter & they all showed the same readings
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Leaky buttons won't show on a basic multimeter test, the keypads are multiplexed and sometimes it's a really retarded way like having an ADC read different voltage levels from different resistors in series with each switch. Just replace all the buttons and it will work fine again.
                        A working TV? How boring!
                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                          by sam_sam_sam
                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                          I am comparing them to a brand new one that I installed
                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                          I going to let it run for several days before I remount back on the wall next to the...
                          09-05-2024, 06:48 PM
                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-12-2024, 02:30 PM
                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                          09-06-2024, 08:10 PM
