Panasonic TC-P60GT30
  • vivisectt
    • Jul 2016
    • 7
    • Usa
    Tv just went black with flickering horizontal lines while watching it the other day. I unplugged it for a few hours, the picture came back for 10 seconds then was back to no sound or picture. The standby led works normally with no error code. Here's a video of the screen when turning it on: https://youtu.be/OqB1eHosGF4
    I've taken off the back and don't see any signs of damage to the caps or anything. A push in the right direction would be greatly appreciated.
    Thanks,
    Seth
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P60GT30
    Take the back off and check the mounting screws on the sc and ss are tight. Bad earths may be causing an issue otherwise I'm thinking it may be a-board. The earth pads under the sc can also arc and burn so may be worth taking the board out and checking / clean these so there is good connection.
    I would do this first before turning this on again as the sc can blow up with bad earths
    • vivisectt
      • Jul 2016
      • 7
      • Usa
      Thanks for the response, it does sound likely that it could be a grounding issue because I did have a service person come out while the tv was under warranty and he replaced a couple boards, A few months after he did the repair I was getting a shadowy flickering, possibly not tightening them down completely, tho if I'd tap on the back of the cover the problem would go away.. . I ordered an ss, SC and sub power boards just in case since they were reasonable on eBay.
      Thanks again!
      • vivisectt
        • Jul 2016
        • 7
        • Usa
        Originally posted by tw2005
        Take the back off and check the mounting screws on the sc and ss are tight. Bad earths may be causing an issue otherwise I'm thinking it may be a-board. The earth pads under the sc can also arc and burn so may be worth taking the board out and checking/ clean these so there is good connection.
        Saw this on the ss board, sign or arcing ? The screws were definitely loose. Also noticed some kind of liquid near the blue caps, possibly a faulty cap?
        • tw2005
          • Oct 2011
          • 6458
          there's no liquid in those polyester caps and yes that black area you can see how the contact has etched away. I reflow those and then clean the chassis where you will also see black marks.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            When you are going to install the boards use lockwasher screws.
            • vivisectt
              • Jul 2016
              • 7
              • Usa
              I reflowed the solder and cleaned up the chassis contacts and still having the same issues. Is it possible that the panel has gone bad or is it definitely one of the boards?
              • vivisectt
                • Jul 2016
                • 7
                • Usa
                Thanks I'll definitely do this when the new boards come in.
                • vivisectt
                  • Jul 2016
                  • 7
                  • Usa
                  So I replaced the SS board and after replacing it I got the 6 code blink thought that was interesting since it wasn't doing that before. I then went and replaced the SC board it then stopped giving the 6 code blink and went back to the black screen with flickering lines. So what's next an A board?
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    by sam_sam_sam
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    09-06-2024, 08:10 PM
                    HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
