Panasonic TC-P65VT30 Click Click Click
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TC-P65VT30 Click Click Click
    You cant buy a new tv for $100 so its totally worth it. Picture quality is great.
    • dzp1
      • Jul 2016
      • 13
      Agree! Thanks for your help!
      • tw2005
        • Oct 2011
        • 6458
        Originally posted by dzp1
        Sears Parts Direct is showing the two chips as in stock. I do not have access to an EEPROM reader - been a while since I've done that, but that would clearly be the easiest.
        something like this but the clip was really crappy and would suggest a new led with 3M or Pomona clip.
        I saved a 1 blinker A-board using this with bad eeprom data, copied from a good spare Board and reflashed the bad one. That was fun.
        Does series type 24 and 25 chips which you have to identify as the pin outs are different when setting that up.
        Pretty cheap even just for a bit of fun.
        • dzp1
          • Jul 2016
          • 13
          Just wanted to close the loop on this. I sent in my A-board to PTS and they sent me back a refurbed A-board. Popped it in and the TV fired right up! I still have the A-board from the 55" and am waiting for the two ICs to arrive, but at this rate, I am thinking I may never get those ICs.
          Thanks for the help from everyone!
          Scott
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Glad it works again!
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
