LG 60pv450 - test pattern mean z-y subs OK?
  • daneyuleb
    • Jul 2014
    • 21
    I have a hopefully quick question regarding test patterns. I have a 60pv450 LG Plasma.
    The test pattern jumper gives me perfect test patterns. Buttons respond, but without the test pattern jumper in, I get a green, pixelated screen with illegible menus (with sound) on any port without signal, and dark screen on those ports with signal applied. Unplugging z and y subs together or individually, still hear the sound, but dark (no green screen).
    My question is--since I get a perfect test pattern (with the jumper in the control board) does that mean the z and y sub cards definitely aren't bad? (And it's the main board or possibly the control board?) Or can you get a good test pattern even with one of those cards bad?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 60pv450 - test pattern mean z-y subs OK?
    You have a bad main board. I fixed 2 of this model number already. My main boards had 2 versions, the only difference is the plug on the side is turned 90° . It still fits and works.
    • daneyuleb
      • Jul 2014
      • 21
      I think you're right--I was just wondering if the experts on this board consider a good test pattern enough to absolutely, positively conclude it CAN'T be the z and y sub boards.
      (I actually ran a heat gun on the main board earlier, by the way, which got me from no video at all to my current situation. I'm going to try it again.)
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I am 100% certain it is the main board. Reflow may work, for how long???????
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          If done properly and you replace the heatsink with a good one maybe fan cooled yes can last for long maybe.
          • daneyuleb
            • Jul 2014
            • 21
            When I first got this tv, after replacing a fuse, it only had standby--no video at all, no pattern, and no buttons worked. After first try with heat gun (low setting, 4 or 5 minutes moving over most components but concentrating on the main chip) it got to this state--sound, and green screen when there's no signal (goes black when there IS signal on hdmi) and working test pattern.
            Tried two more times with the heat gun, low setting, a few minutes longer, but no change.
            I see replacement boards at around $100.00 so I'll probably have to go that route. Mine is EBT61663001 which seems to be harder to find than some other versions--I'd love to repair it though. Anyone know if there's a repair kit for these things--or any component that's most likely to be the source of the failure I could gamble on replacing?
            If not... I'll probably make one last go with the heat gun--nothing to lose. I'll go longer and maybe even on high for a bit... at this point I'm going to either fix it or melt it.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              You will need to properly reflow the Cpu and maybe even replace and reball a new one in to sort it I would say. If not buy a replacement mainboard and then put a better heatsink on the Cpu help it last longer.
              • daneyuleb
                • Jul 2014
                • 21
                Thanks for that info, as I'll be getting a board soon. Do you have a good source, or just ebay and hope for the best?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  No worries, also I always tend to use ebay. Keep us updated
                  • nono34
                    Hisense stuck in Colors cycle like test pattern.
                    by nono34
                    I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                    I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                    10-24-2024, 04:31 PM
                  • m3tal82
                    Sony Bravia XBR-65x900e Test pattern
                    by m3tal82
                    Hello all,
                    I got this beauty of a 65" Android Smart TV from a roommate whose boss through it out because it didn't work. I've fixed a few TVs before, but was being stupid on this one:
                    Original issue:
                    TV powered down after a minute or so, but picture was fine.
                    Tried replacing main board, which didn't work. I should have just replaced the AC Power board.
                    Months later, I replaced the power board, so I can see the screen. I lost / threw out my original main board, and there is now what I believe to be a defective main board in the TV. My symptoms...
                    04-07-2020, 12:41 PM
                  • chth96
                    How Can I test PWM DM0365R?
                    by chth96
                    Hello
                    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                    06-18-2025, 04:14 PM
                  • Jeryswan
                    Intermittent color test pattern issue.
                    by Jeryswan
                    I've got a LN-T4065F which came into my shop with the customer complaining that the test patterns would randomly come up on the screen. Upon testing, the pattern came up on the screen after about 20 minutes of use. We opened it up and did a visual inspection to see if there was any dust or bugs shorting out anything on the board that would generate the test patterns. I'm a bit new to TV repair but on a plasma tv that we recently worked on we strapped out the auto ext on the control board and it generated test patterns on the screen. My thoughts was that maybe something was shorting out that circuit.......
                    10-14-2020, 03:21 PM
                  • handsworth
                    Vizio D55UN-E1 test pattern
                    by handsworth
                    Hey, Got this tv for free. Works fine, great picture except that if you unplug it and turn it back on, it goes to test pattern. (red, green, blue gray, black full screen). Menu, inputs and channel info show as they should, so I dont suspect tcon. If I do a factory reset, the tv performs as it should. Only if I disconnect the power does it go back into test mode. Is the eprom corrupt or can I remedy this in service mode? Any ideas are appreciated.
                    05-30-2021, 11:21 AM
