Sony kdl50r450a
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Sony kdl50r450a
    I have standby LED. small green LED to the left of SONY logo. No BL, No Audio,
    no reaction to on button or remote. No blink codes present. Here are the readings I got on the main connector for the harness from SMPS to Main:
    1-5.02V
    2-3.8V
    3-3.29V
    4-12.6V
    5-0V
    6-0V
    7-0V
    8-12.6V
    9-12.6V
    10-0V
    11-0V
    12-0V
    13-Blank, no wire
    14-0V
    15-0V
    I am missing BL-ON, 12.5VT(I assume T-Con), and TCON_ON. Does 12.5VT originate from Main board?
  • Diah
    • Feb 2013
    • 6435
    Re: Sony kdl50r450a
    since there no blinking code, and ps-on exist its highly firmware issue,
    • anmol
      • Mar 2012
      • 73
      • India
      Re: Sony kdl50r450a
      no reaction to on button or remote mean you need to change Main board.
      Regards.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Sony kdl50r450a
        Thanks. I have one ordered.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Re: Sony kdl50r450a
          I sure have had a rash of SONY main board failures the last two months. Some of them very hard to find!
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Re: Sony kdl50r450a
            Main board, did indeed restore functionality. Sluggish to react to remote commands when first fired up..Will check in a few hours..after burn in.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Re: Sony kdl50r450a
              Slow to start video and audio on a cold start..could it be that is normal as they crammed everything on this tiny main board? Once it starts, it works fine..
              • anmol
                • Mar 2012
                • 73
                • India
                Re: Sony kdl50r450a
                You have try to upgrade firmware ?
                Regards.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Re: Sony kdl50r450a
                  None available on Sony website.
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • cheeky2
                    Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                    by cheeky2
                    For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                    See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                    01-08-2024, 05:56 AM
                  • joby91
                    SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                    by joby91
                    I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                    I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                    I found one chat about firmware on ************** forum but i cannot read the comments.
                    https://**************/forum/108-114100-1#880537
                    09-04-2024, 01:34 PM
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
