LG 50 PS 3000 - Still No picture after ZSUS repair
  • Ven
    • Jul 2016
    • 46
    I have a LG PS 3000. There is no picture but sound is OK. There was a very bad quality picture in the very beginning but I saw that only once. Never any picture appeared again.
    After finding a similar LG TV service book. I found that :
    • Power Supply Va 64V is ok
      Power Supply Vs 192 V is OK
      Power Supply 5V is OK
      YSUS 64V Fuse is OK
      YSUS 192V Fuse is OK
      YSUS 5V is OK
      YSUS 5V is OK
      YSUS -VY is -175V is OK
      YSUS VSC 138V is OK
      ZSUS Zbias is 0V
    3 mosfets were all short circuit on the ZSUS. I found from ebay that there is Repair Kit just for this repair included all Mosfets, a zener diode, some resistors and some capacitors. ( http://www.ebay.co.uk/itm/281685799774 )
    So I replaced all now I can see Zbias voltage came back. Zbias is OK now. But there is still no picture.
    I connected a DVD player and can hear the sound.
    Can anyone help on this please ? Thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50 PS 3000 - Still No picture after ZSUS repair
    Got the same set here same issue only one fet short, does the screen light up in a dark room ? Also did you check the little fusible resistor which I belive is yellow near the input connector on the Zsus heard that can blow if the fets do ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Run test pattern.
      https://www.badcaps.net/forum/showth...+control+board
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Originally posted by dick_barton
        Might not be that as Zbias is 0 Sounds to me like fuse is gone.
        • Ven
          • Jul 2016
          • 46
          Yes screen lights up, I can see that. But It was already lighting up before too.
          And yes you are right it s a yellow colour fuse, it is OK, and there is another fuse on ZSUS, which is also ok.
          Also, 17V is OK coming from YSUS, as explained on service manual.
          • Ven
            • Jul 2016
            • 46
            Zbias is OK now, after I changed that kit bought from ebay. It is same as shown on the sticker on the back panel.
            • Ven
              • Jul 2016
              • 46
              Thank you for the reply but it mentions for Samsung and Panasonic TVs. Mine is LG. Am I missing somethings ?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ok then possibly your mb or control board isnt working, jump the auto ex gen pins on the control board and start the Tv with the Lvds cable removed.
                • Ven
                  • Jul 2016
                  • 46
                  OK, I have to study this first because I dont know how to do it.
                  BTW, 2 x 3.3Volts and another 2.5 V is OK on control board as shown on service manual. There are 2 LEDs one is solid and other one is flashing.
                  How to jump ex gen pins on the Control Board, do you mean Auto Gen(Thats what I see on the Control Board) ?
                  If so it is a free socket, 4 pins and no connection.
                  And If I manage to do that, how is it going to help me ? Thanks
                  • mmartell
                    • Oct 2013
                    • 3189
                    Try jumping middle two pins. If you get test patterns then your main board is likely shot.
                    • Ven
                      • Jul 2016
                      • 46
                      I managed to put it in Auto Gen. A series of patterns appeared on the screen, all look good.
                      So in this case main board is faulty ?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        yes you will need a replacement main board
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Yes the Mb is failed, its probably the bga solder on the cpu which is the device under the heatsink. Try reflowing the cpu.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            You can try to reflow it yourself since you would have nothing to lose.
                            I'm sure that someone who has successfully carried out this task would be willing to advise you.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              I have check my 50ps3000 repair video out shows that them boards have issues with Bga solder, I did actually reflow that and try it in another one I got that has bad Zsus but it wadnt perfect the Hdmis didnt work and it sounded odd so guess it probably needs reballing.
                              Im making a video on the chips used on these Lg boards, Lg's XD engine get very hot and Lg just dont heatsink them well enough so they fail very common.
                              • Ven
                                • Jul 2016
                                • 46
                                Just in 1 min after switch-on Main chip on the Main Board is very very hot, nearly can't touch to heat sink. Thank you.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  On the replacement board you should remove the heatsink and reapply some thermal plaster to glue to heatsink down (only use silicon thermal plaster) then maybe add a little fan to it as the pm chips get VERY hot and will die fast. Also use fresh thermal plaster as it works alot better than the orginal thermal pad which is probably dried up on the heatsink so remove that.
                                  • Ven
                                    • Jul 2016
                                    • 46
                                    Thank you everyone, I will update as soon as I have any news.
                                    • Ven
                                      • Jul 2016
                                      • 46
                                      UPDATE : After replacing the Mainboard Tv is working fine now.
                                      So there were 2 problems.
                                      One was Zbias and other one was Mainboard itself.
                                      Thank you all for your help.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Awesome work now cool that chip better some how
                                          LENOVO 3000 J110 3000 J E6300 Specification for Upgrade or Repair
                                          This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...
                                          09-12-2024, 03:36 PM
                                          ACER Predator Orion 3000 PO3-600 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the ACER Predator Orion 3000 PO3-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-600 boardview and Predator Orion 3000 PO3-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                          ACER Predator Orion 3000 PO3-620 Predator Orion 3000 i7-10700 Specification for Upgrade or Repair
                                          This specification for the ACER Predator Orion 3000 PO3-620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-620 boardview and Predator Orion 3000 PO3-620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          ACER Predator Orion 3000 600 I9200 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the ACER Predator Orion 3000 600 I9200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 600 I9200 boardview and Predator Orion 3000 600 I9200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
