Sanyo dp55441 "no signal" please help!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Sanyo dp55441 "no signal" please help!
    No not really. You can download the schematics of the board and measure every single component but that takes a lot of time.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by Moreno83
      No hard feelings Diah , i get your point but with lighting atleast 1 chip gets shorted. It will take more parts with him
      Hope a reflow will work! Fingers crossed.
      +1 agree Diah is wrong here.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Probably shorted Ic then best just to replace the board.
        • Georgia088
          • Sep 2014
          • 109
          Ok. Just to be sure. eBay sales a "431C4169L01" my board is a "431C4169L02" will this L01 work in my tv? Thanks!
          • jomede
            • Mar 2011
            • 16
            did you ever figure out what the problem was on this set?
            • AstutePauciloquent
              Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
              by AstutePauciloquent
              Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
              I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
              11-23-2023, 11:02 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • karthur
              Sanyo DP55441 - No brightness control
              by karthur
              Recently picked up a Sanyo DP55441. Set has a few issues:
              1. When I turn it on, I always have to select either "Store" or "Home" on the menu (see attachment).
              2. It forgets which input I was using last, so I have to change the input setting everytime.
              3. The controls for Brightness, Contrast, Saturation, Hue and Sharpness are not available from the menu (see attachment).
              Besides these issues the set works good, no other issues that I know of.
              I am thinking all three are related and its probably the main board. I have looked...
              06-19-2022, 08:09 AM
            • JayPoorJay
              Converting +/- 5v to a Usable Hz Signal
              by JayPoorJay
              Good morning.
              I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
              This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
              The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
              08-07-2022, 08:35 AM
