Samsung UE40D5000 , Does not turn on.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Working on my very first LED tv repair.
    Bought it with the symptoms that the screen just went bla k.
    After searching this forum i found out that this model has alot of problems with the led failing.
    I removed all parts carefully untill i reached the leds and they are visibly ok.
    Reinstalled the boards and nothing but 5 blinks. No backlight.
    Removed the cable between the mainboard and the powersupply and the backlight turns on. All leds are working.
    This make me believe that the mainboard is not turning on the backlight OR tv. I dont hear any sound and there is no image visible on the lcd with a flashlight.
    Bad mainboard?
    Re: Samsung UE40D5000 , Does not turn on.
    Did you check the BL-ON to see if it is present?
    Sounds like main board problem. Try heating/cooling the main board?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Ps , voltages on the powersupply are all good. 13 and 5v present.
      When i turn on the tv the led is blinking 6 times and then goes away. Only responds to the remote , not to the touch.
      Already tried a eeprom reset but still the same problem. I'll reflow the cpu and see what happens.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Common issue failed Bga solder on the cpu, have the same model same issue. Also had the C5000 same issue crappy small heatsinks on bga chips never good.
        • Diah
          • Feb 2013
          • 6437
          try remove the touch control boards
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Well just disconnect it dont remove.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Thanks Diah but its not a shorted touch panel.
              I did what Reecey/Budm said and reflowed the cpu. Added some flux and heated the cpu for 3 miutes and let it cool for 20 minutes.
              Installed the board and backlight came on. Will install the panel tomorrow and see if its working properly.
              Thanks buddys!
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Awesome told ya it would be that, you should replace the heatsink with a good one. The little thermal pad under it dries up and fails to cool the chip.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Haha indeed! Will add a better one with new cooling paste. Hope the panel is still ok , i read that they are "bad".
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    They are ok tbh not the best just regular Samsungs really lol
                    • Diah
                      • Feb 2013
                      • 6437
                      cross the finger lol... when Reecey become excited.. the party ended fast... good job.. cheers.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Ok good! I mean the tab bonding. Disassembling the panel is such a tricky thing.
                        Will update the thread tomorrow with more pics
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Placed the LCD panel back into the tv. I noticed that the small print/tab bonding is not screwed to the chassis , its just hanging there. I used some electrical tape and placed it carefully onto the chassis so it can't go anywhere.
                          They also used very cheap screws in the chassis , i replaced them all by screws from a philips panel.
                          I used a laptop heatsink and glued it to the original small heatsink. Thermal paste on the cpu and placed the heatsink on the cpu with some silicon and let it dry for an hour.
                          Tv is working perfectly. I do see 2 small black area's when the screen is just white , its probably my fingerprint/dust or something. I just left it as is and gave it to my father in law , he had a 2007 panasonic and was very happy with this tv.
                          Happy ending on my first LED tv repair!
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            What does that even mean lol ?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Awesome work, now remember turn down the brightness of the backlight help stop any Led failures
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                Indeed Reecey , it was by default on 20. I tried 9 but was a little dark and it's now on 12. Im gonna order a replacement mainboard + leds ( DURIS E5 ) just to be sure and if the panel is not failing i can always repair the tv again.
                                thanks for the help m8
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  No worries, I also suggest you replace the heatsink on the cpu with a bigger one and secure it with thermal silicon.
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    I did! I used something similar like this :
                                    http://www.rmcybernetics.com/shop/im...-1280x1024.jpg
                                    Placed it on top of the original heatsink with glue and used silicon to glue it to the mainboard. Its not going anywhere
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Yeah something like that or even a thermal pad to transfer heat to the metal backing.
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        Ordered thermal pads on eBay. Good suggestion!
                                          09-07-2024, 05:50 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • bohaboha
                                          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                          by bohaboha
                                          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                          04-19-2025, 01:47 PM
                                          09-06-2024, 11:40 PM
