SAMSUNG LA40N81BDX coloured vertical lines appear then switches off
  • syaoran123
    • Jun 2014
    • 178
    Hi there, my first thread here.
    Have a SAMSUNG LA40N81BDX that behaves in the following sequence:
    1. Power button is pressed
    2. Clicks on like normal, blue light near samsung logo turns on, backlight flickers on
    4. 5 seconds later, back light turns on while coloured vertical lines progressively fill the black screen. The lines are solid.
    5. 10 seconds later, another click is heard and everything is switched off.
    6. Repeats
    I have deduced it to be the main board, rather than the screen/t-con board due to the fact it is switching off and having no response to the remote. Have already changed the EEPROM and already tried heating up the processors with a heat gun.
    Anybody else have this sort of experience? I want to try repair the board to component level because they are expensive/hard to find.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: SAMSUNG LA40N81BDX coloured vertical lines appear then switches off
    So heating the Mb has no effect but heating the Tcon does ?
    • syaoran123
      • Jun 2014
      • 178
      Only heated the MB processors underneath the metal shield/heatsink which had no effect. Havent touched the T-con. Can it really cause the TV to turn off?
      Edit: actually it responds to the remote power button only. No menu displays appear.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        That would be the Mb Id say normally two 1000uf caps under the cpu heatsink that cause the set to crash after heat up but normally heating that area causes it to fault out.
        • syaoran123
          • Jun 2014
          • 178
          I heated it while the heatsink was on actually. But i will remove the heat sink later today to see if i can find any 1000uf caps.
          • Diah
            • Feb 2013
            • 6610
            before it shut down press power on RC and let it go in standby mode, then from this STY mode go direct to service menu.. when it switched to service menu.. press source for signal... and keep it so to see how long it will stay on.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              What does this exactly do ? I have a Samsung here does nothing when you do that ?
              • Diah
                • Feb 2013
                • 6610
                his Tv turn on, only had bad screen then turn off after few seconds. from stand by to go service menu, if it show menu list normal then eeprom data corrupted . can easy to recover them next step.. if there no menu.. then go forward to other inspection on main boards.
                • syaoran123
                  • Jun 2014
                  • 178
                  No service menu. Just tried it
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Does this tv also have the extra board above the mainboard?
                    • syaoran123
                      • Jun 2014
                      • 178
                      No extra board
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Ok , as Reecey said. Try to heat the mainboard. I have a similar model with the same mainboard but has a extra board.
                        My tv also had lines when the board cooled down but when i heat it the lines go away.
                        So try to heat the board for a longer period of time and see if it stays on. The problem is most likely bad capacitors.
                        • syaoran123
                          • Jun 2014
                          • 178
                          So I removed the heatsink and this is what i see. Which part do you think is faulty?
                            09-07-2024, 05:50 AM
                          • polaro
                            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                            by polaro
                            Greetings,
                            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                            08-27-2022, 08:46 AM
                          • Falki
                            Colorful LCD Vertical Lines on Samsung ue55es8090
                            by Falki
                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                            A similar issue has been posted as well but also with no actual response ...
                            08-12-2025, 04:19 AM
                          • pni
                            LG 49uf695v vertical coloured lines
                            by pni
                            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                            11-14-2025, 03:15 AM
                          • jeyoung12
                            Samsung QN50Q60t lines on screen
                            by jeyoung12
                            Hi all
                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                            So....i don't know what end of the C ribbon to work with...
                            02-26-2024, 10:38 AM
