Power supply no work, tv dead
  • neodark
    • Jul 2016
    • 15
    • spain
    Hi, I has a TV that has power supply 17IPS19-4 and the TV no led power, only the power supply has a noise, the small square yellow coil from the first pic has a noise (on the first pic, right-medium side).
    All de diodes are OK, with the tester in direct measure has about 240 measure and indirect test infinite.
    The capacitors has their correspondient voltage (12 volts and 24 volts) and I don´t know how to continue procced.
    The burned part on the first pic is for heat solder, no component burned.
    Can anyone help me?
    Thanks!!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Power supply no work, tv dead
    So you have 12v in the output capacitors ?
    • neodark
      • Jul 2016
      • 15
      • spain
      Hi, yes, all the capacitors has voltaje, some 12 volts and some 24 volts.
      It´s very strange...
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        The Psu is fine then the fault is on the mb, guessing 17mb82 or 95 ? Also the part thats caused the hotspot check it for S/C with your meter just to make sure its ok.
        • neodark
          • Jul 2016
          • 15
          • spain
          Hi, it´s 17MB82-1A but I has a question, If I disconnect the power cable from PSU to mainboard, the PSU still noising... Is it right?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Lol yeah them Psus make a horrid noise when they work, the main Cpu on the mb is dead its because Vestel didnt heatsink it properly. You need a new motherboard for the exact Tv with VES315WND? When you get a new board you should add a heatsink to the cpu with a good heatsink and thermal silicon.
            • neodark
              • Jul 2016
              • 15
              • spain
              Hi, then my mainboard is dead and the PSU is OK?
              Can I change only the CPU of the mainboard?
              I diassembled the main board and has a thermal rubber from solder side to the screen plate.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Yes the Psu is fine, it only generates 12v and 24v matey, the Mb is dead. You can change it but there might be more wrong with it very hard to fix they are tbh.
                Also yes the rubber pad does cool the Cpu but its rubbish and Cpu gets very hot and overheats in time so best to also add a heatsink to the board too like this:
                • neodark
                  • Jul 2016
                  • 15
                  • spain
                  Oh, thank you so much for your support... Best regards!!
                  • neodark
                    • Jul 2016
                    • 15
                    • spain
                    Hi, I suppose that PSU don´t generate 3v3. In the motherboard I has a (i suppose) a FET marked as U21 where in a pin has 5 volts and in output has 3V3 but but but this voltaje don´t arrives to MT5820.
                    I read continuity with multimeter and from ground to 3V3 line I has only 1 ohm... Possibly shortcut in 3V3 line. I lift the two 3V3 (power IC) legs from MT5820 to check if the shortcut comes from this IC but no, the IC is not in short cut... I think the trouble can be another component that prevent to 3V3 arrive to all components such as MT5820, serial flashs, etc...
                    Any idea? Anyone has this board and can check if resistance from ground to 3V3 line are about 1 ohm?
                    Thanks!!
                    • neodark
                      • Jul 2016
                      • 15
                      • spain
                      Forget the previous message, this is the scheme and has a U49 IC that is the one that provides 3V3. In the input has 5 volts but no output.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Yes they do have that sorry however its only turned on when the Mb is, the Mb has its own switching sections for 3.3v and then sends back to the Psu to turn that section on which is for the Led drive circuit not for the mb.
                        Also it shows short due to the resistor network has low ohms between the pins this is normal and just to confirm I have the same Pcb here fully working and its the same. So the Psu is deffo ok.
                        • neodark
                          • Jul 2016
                          • 15
                          • spain
                          Oh, ic, thanks for your help my friend!!
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            No worries keep us updated after you have replaced it
                            • Andreas_de
                              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                              by Andreas_de
                              Hello!
                              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                              04-12-2025, 10:38 AM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • CMCM
                              Russound CA4 Power Supply Repair
                              by CMCM
                              Hello Everybody,
                              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                              The outputs marked 12v and 20v are all measuring only 1v.
                              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                              The capacitors physically look clean (no bludgesor leaks) and...
                              07-03-2025, 01:12 PM
