AOC L32WA91 - No Backlights
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Set is an AOC L32WA91. The service manual for the L32W961 power supply appears to be identical.
    The set appears to be working, volume up / down but the backlights are not working.
    There is not even a quick flicker from the lamps when the set it taken out of standby.
    Removing the cables from PSU to the main board and switching on and the backlights still fail to come on or flicker.
    Using a CCFL tester the tubes have been tested and they all light up.
    The inverter transformers have been checked and readings given below.
    For the transformers on the inverter board the minimum secondary resistance is 1445 ohms and the maximum 1496 which may be slightly above the recommended tolerance.
    The driver chip is OZ9976 and shorting the timer input Pin 11 did not result in any change. The two mosfet drivers checked out OK out of circuit.
    Power supply: 715G3332-1
    Inverter: 715G3333-1
    I'm suspecting the OZ9976 IC but any hints gratefully received
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: AOC L32WA91 - No Backlights
    Are you getting boosted Pfc voltage across the cap matey ? Also whats the input voltage to the driver fets ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Hello Reeceyburger123
      I'm getting 394V across the cap (C920) out of standby.
      At R801 (fusable resistor) feeding the mosfets the voltage is 390V DC with respect to the negative leg of C920.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok buddy, sounds like your on the right track about that driver chip. As the fets are getting the feed voltage sounds to me like they are not being switched.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Thanks for your input ReeceyBurger123. Time to get the scope out and check the drive but that will be tomorrow now. In the meantime I'll check out D802, D804 and C802.
            There are many version of this 715g3332-1.
            Which one of these has the matching barcode #?
            http://www.shopjimmy.com/catalogsear.../?q=715G3332-1
            Hopefully you can get to the site, otherwise please provide what is printed on the barcode.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Hello BudM
              It looks very similar if not identical to this one.
              AOC ADTV8LCCMACF Power Supply for L32W961
              The partial barcode on my board is (T)8LCCMAEF
                Please look at the bottom side of the board, there are many pins that has 'RESOLDER' right next to the pins.
                http://assets.shopjimmy.com/media/ca...f-bottom_1.jpg
                This board is the power supply-inverter combo, the output ACV is about a couple hundres Volt and is fed to the step up transformer on the sub-inverter board to step the Voltage to thousands of Volts to drive the lamps.
                  So you have the service manual with the diagram for the power supply/inverter combo board?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Hello Budm,
                    The bottom of the board looks identical. One of the first thing I did was to resolder the pads around the HV transformer and mosfet driver end since they all looked rather grey but that appeared to be due to the lead free solder.
                    Edit#
                    Yes I have that pdf in front of me on the laptop.
                      Looking at the board, the two power MOSFETs are driven by the Gate drive transformer so It will be good to see how that IC drive the primary side of the Gate drive transformer.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        They are driven by the OZ9976 which has 12V supply and is enabled. I'll have the scope out tomorrow to check if there is any drive.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Thats what I would do.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Here are the waveforms at the primary pins of T801
                            The scope signal is recorded 1/20th of its value so approximately 240V amplitude at 20ms
                            Edit
                            Thinking about it the results don't make sense. The OZ9976 is only driven by 12V so I cannot see how it could drive the primary at those voltages. Need to repaet test and repost results.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              I above measurement were incorrect and explains why they did not make sense.
                              Measuring the signal on T801 (secondary of transformer driving the mosfets), at switch on the drive signal remains low and after approximately 4-5 seconds the signal appears 13.99v peak to peak at 44.73Khz for 1.5 seconds and then falls back to 0V.
                              There is no flicker on the lamps during this time.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Re: AOC L32WA91 - No Backlights (Fixed)
                                So the OZ9976 was attempting to bring on the backlights so decided to replaced the inverter board. Set now up and running as normal.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Have had a chance to look at the redundant inverter board. Most of the solder joints are very dull grey and could all do with resoldering.
                                  Watch out for the jumper links that they do not fall out when doing this.
                                  The secondary windings of all 12 transformers are linked in series and one of the links had a very poor solder joint which was probably the fault.
                                  I'll keep the board to one side. It may come in useful at a later date.
                                  • x_orange90_x
                                    by x_orange90_x
                                    01-29-2025, 09:24 PM
                                  • fixit007
                                    Samsung flicker - BN44-00932T board or else?
                                    by fixit007
                                    I picked up this TV that the prior owner said - just died.
                                    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                    05-04-2024, 06:14 PM
                                  • Storyteller12
                                    Vizio M801D-A3 backlights flicker
                                    by Storyteller12
                                    Need a little help here.
                                    the backlights flicker when watching tv. Everything else works as it should. Also it's not the picture that's flickering just the leds.
                                    I tested the leds and all light up and measure 77.5v volts. I took the tv apart to double check leds and they all work and light up perfectly.
                                    I believe it's the power board causing the issue however I cannot find a replacement board so I'm stuck to finding the bad component. The power board has a sizzling sound coming from the backlight transformer. I replaced that and problem persist....
                                    05-25-2021, 11:17 AM
                                  • lostone
                                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                    by lostone
                                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                    05-19-2024, 11:40 AM
                                  • Jackching
                                    LG 50LF5800-UA Backlights flicker on and off
                                    by Jackching
                                    So i ran tests on the power supply and all of the voltages going to the main board are fine. I tested all of the capacitors on the psu with an esr reader and they all pass. All diodes pass also. But when a reading is done on the 4 pin white led connector on the top of the board, the voltages will flicker to 5Vdc for a fraction of a second and go out again. For that fraction, the LED backlights light up. Anyone have any clues to this situation?...
                                    02-04-2021, 04:24 PM
