NEC PlasmaSync 60XP10
  • Crashtek
    • Jul 2016
    • 8
    Please excuse my amateur noobiness here. I have the aforementioned plasma screen. It won't turn on when cold. If it's warm it will turn on and off fine and stay on. When I try to turn it on the power supply clicks and I also here a click in the main board then the red LED comes back on. The second click seems to be a circuit protection shutting the unit back off due to a fault. If I unplug the four wire harness from the power supply, which seems to be the main power out to the Ysus, the Green LED illuminates and stays lit. I've also found that if I leave that plugged in and unplug BOTH the small wire harness plug from the Ysus to the XRLBT board AND the wire harness plug from the Ysus to the Zsus, the Green LED will illuminate and stay on.
    Any ideas or steps to take to further troubleshoot? I do have a DVOM.
    Thanks in advance for the help. I have attached a picture of the back of my screen if it helps. The arrows are the two plugs that I unplug to get the Green LED to stay on.
  • Crashtek
    • Jul 2016
    • 8
    Re: NEC PlasmaSync 60XP10
    Anybody? Help please.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      That 1st 'click' makes me think the Pwr Bd is OK and the 2nd 'click' suggests to me a problem in the Y-SUS Bd.
      • Crashtek
        • Jul 2016
        • 8
        Before I replace it I'm curious as to why it would work Ok with the Y sus connected but the left lower buffer and X sus disconnected from it?. is it normal for all the power to flow through the Y sus to the X sus?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Lol I see badcaps on the second psu down cant you OP ?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Theres several badcaps in that second psu down, this will be the issue. Ysus is probably ok:
            • Crashtek
              • Jul 2016
              • 8
              How can you possibly see that from that picture? Do you think that would cause the problem with the unit working with the Z sus and buffer unplugged from the Ysus?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I have good eyes and them caps blown out are common for this chassis. They are 3300uf or something ? Do you know how to diagnose and replace caps ?
                • Crashtek
                  • Jul 2016
                  • 8
                  I can solder and replace. I can use the ohm then voltage charge and discharge test but that's it. I can buy the whole board for $38.00 too. But any advice on a better way to diagnose and replace would be great. My DVOM is a cheap Innova 3320.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Well then replace the failed caps, what are the values of the bloated ones ?
                    • Crashtek
                      • Jul 2016
                      • 8
                      Ok. I ordered the caps, replaced them and put back together. Works good so far. Thanks for the help.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Awesome work knew it would sort it
                          Interesting to see this is an LG panel, my dad's 50XR5G is a Pioneer-NEC panel (now about 12 years old and 25000 hours usage, still doing well.)
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            I believe Tom that Nec also used FHP as well for their Pdp's they never used Shitsung though ?
                            • PlasMatt
                              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                              by PlasMatt
                              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                              09-20-2025, 06:50 PM
                            • legg
                              LG 42PC3 buffer output doesn't follow YSUS
                              by legg
                              LG42PC3D -UD originally with green lamp but no display or audio.
                              Owner says was working, then went 'pop'.
                              All 5V caps bulging. replaced.
                              All PSU output voltages within spec but -Vy is low on YSUS.
                              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                              eventually shorts DG. Replaced all 3 - -Vy now OK.
                              Y scan buffer test point does not follow YSUS output below -50V
                              Note: This unit seems to expect YSUS output to park at -Vy in between
                              drive signal pattern periods. A replacement drive signal board confirms this....
                              11-18-2021, 11:49 AM
                            • oneduane
                              Samsung Plazma Blues Model PN59D550C1F
                              by oneduane
                              I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                              09-07-2023, 08:17 PM
                            • huj3r
                              Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                              by huj3r
                              Hi there!
                              I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                              Photo of the situation after the black shadow dissipates:
                              After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                              I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                              > This indicates HFR Communication error. [ HFR Communication...
                              08-15-2023, 10:55 AM
                            • Truncatedhose
                              Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                              by Truncatedhose
                              Greetings all!
                              Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                              Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                              07-04-2018, 10:59 AM
