Please excuse my amateur noobiness here. I have the aforementioned plasma screen. It won't turn on when cold. If it's warm it will turn on and off fine and stay on. When I try to turn it on the power supply clicks and I also here a click in the main board then the red LED comes back on. The second click seems to be a circuit protection shutting the unit back off due to a fault. If I unplug the four wire harness from the power supply, which seems to be the main power out to the Ysus, the Green LED illuminates and stays lit. I've also found that if I leave that plugged in and unplug BOTH the small wire harness plug from the Ysus to the XRLBT board AND the wire harness plug from the Ysus to the Zsus, the Green LED will illuminate and stay on.
Any ideas or steps to take to further troubleshoot? I do have a DVOM.
Thanks in advance for the help. I have attached a picture of the back of my screen if it helps. The arrows are the two plugs that I unplug to get the Green LED to stay on.
