Sanyo Dp42740. any hope of fixing this?
  • lllllllBOB
    • Jun 2004
    • 28
    Sanyo DP42740.
    * Problem:
    When plugging it in.. it makes a few clicks.. and a short whining sound.
    - No power light at all. tv will do nothing else.
    * Reason:
    Was knocked off of stand onto the floor. was caught half way. but still hit the floor.
    - and while falling.. the cord was yanked unplugged from the back of the tv while on.
    - Nothing is physically broken. screen looks good. boards looks good. no cracks.
    (My uncle gave this tv to me. his son knocked it over. not me. lol)
    * What I do see:
    - 3 bad looking caps. not horrible looking.. but the're kind of buldging a tad bit.
    - and 1 of the 3 did not seem to charge up much at all when testing using an ohm meter.
    (2 250v 220uf and 1 1000 uf 80v. the 1000uf is the one that didn't test out good.)
    * So my question is..
    Would the fall and the cord being yanked out while on.. finish off the failing caps?
    Or would you say it was something else that may have broken in the fall?
    I would have just went straight for those bad looking caps had the tv just stop working on it's on and had not been in a fall to the floor. huhuh..
    I unplugged the x and y.. and it still clicked. So that says.. it's either the power board.. or maybe the video inputs board? Sorry.. I haven't worked on a flat screen tv before.
    yeh i know.. be carefull. checked the diodes.. seem good. one on the back of power board as well.
    and of course.. the 3 fuses are good too. dang it.. it's never the fuse for me lol
    I usually just fix pc mother boards and stuff like that with bad caps or something.
    I'll search around the junk pile later and see if I can find a 1000uf 80v cap out of something. would be nice if that would fix it.
    What's the usually way of testing voltages on this model?
    .. or will it have voltage to the x/y plug in's if it's not kicking on.
    well.. thanks for any info you may give.
    Hmm: I just thought of something after reading my own words lol..
    Maybe that whining sound is from the bad cap trying to power up?
    I'll have to re connect everything later and listen real closely near that cap.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Sanyo Dp42740. any hope of fixing this?
    Either the already bad caps gave up completely now(passed threshold),or more likely while falling,the shock shorted the panel out for a quick sec and blew a buffer board or the y main. (seen it before where an object gets thrown at the screen,doesn't crack it but the impact shorted the screen out.)
    I would measure the Vs and Va and see if they come up at all,if not,unplug the y main and zsus and measure at power supply again while turning on tv,see if they come up then.
    Voltmeter on DC volt,expect a good 200 volt!,Black probe on back of chassis,red probe on the Va and then the Vs.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • lllllllBOB
      • Jun 2004
      • 28
      Thanks for the reply man.
      Update: :-( nevermind on the power board. or pfft it could be that as well.
      While the screen itself is still not Broken as far as I can see. and after re-checking again....
      ---> There's a nick in one of the flex cables coming from the screen. Ouch. :-/ dang....
      ... the small nick appears to have severed the very outer connection on the cable.
      ---> Would that too give a no power light and no standby light? i'm guessing it will.
      .... nick was is in the curve part of the cable.. as it curves around... I barely even noticed it.
      and didn't even notice it the other hundred times i looked everything over. really small nick.
      and after looking at it a ton.. the connection is indeed severed on the outer strip. booo! lol
      Must have been caused by the fall I guess.. I hate ribbon cables! Wires please. :-/
      I'd rather have a big bundle of wires and it cost more.. than have flex cables... uhgg...
      * And I know how easy it is to fix a broken flex cable. Not very, and mostly if at all. huhuh...
      .. but possible. sometimes.
      Since it is the very outer connection.. I will try to rig something up....
      ..sure won't hurt nuthin. for it don't work anyway.. and it was free.
      Had it been any farther than that outer connection.. I'd say it would be totally non-fixable.
      They could have had connectors on both ends.. and not one end made into the screen.
      ... and thus.. I could have just bought a 4inch long new cable. :-/ stupid tv sanyo makers.
      I will first.. scrape it to the copper with a scalpel very very carefully..
      ...trying not to damage the next needle size connection strip.....uhgg...
      and then use some solder paste or something like that? Any suggestions on paste?
      or foil tape.. or aliminum foil glued over it. lol :-D for it just needs to make a connection.
      ..yeah.. some solder paste.. and then some conductor tape on top.. yup.
      and I know.. don't even try to hot solder no flex cable.. unless it's has really wide connection strips...
      and this one does not. needle size strips on this. jeeeez. ouch. real tiny...
      I would bet money.. if I do fix this cable.. the tv will still not work. lol! it will be sumn else too.
      I Will update this post if i manage to rig up that cable...
      But either way.. I knew the Fall.. should have damaged something.. Hope that's the only thing.
      • cj_reha
        Mystery 80s Sanyo cap - perhaps polymer?
        by cj_reha
        Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
        01-06-2023, 09:24 AM
      • grimacelord
        Sanyo DP42740 - Powers On, No Video - Missing 15/25v
        by grimacelord
        TV original came to me with no power, no LED, no sign of life whatsoever. I took some initial voltage measurements and found the SN board had multiple shorted components on the board and I found a replacement cheap enough so I replaced the SN board. I also bought and installed a repair kit for the main power supply board. Now, the TV shows some signs of life, but it still isn't there yet. I scoured through all of the threads here about this model, but haven't found anything similar to this particular problem. Here is what it is doing now:
        When I plug in the TV to power, I hear the...
        03-19-2019, 07:21 AM
      • fharris1977
        Sanyo DP65E34 Backlights off after a 1-2 sec
        by fharris1977
        Hello. I have a Sanyo TV that had no backlights at first. I changed CS9 off the power supply and now the backlights will come on for a second or 2 and go right back off. I can see the image if I shine a flashlight in the screen. Anyone familiar with this particular model and problem, your help would be greatly appreciated. Thanks in advance....
        03-14-2023, 01:13 PM
      • EFritz20
        Capacity challenge for Sanyo OS-CON 510uf 4v on older GPU
        by EFritz20
        Hi guys/gals,
        I have this geforce 2 card that needs a recap.
        It contains some nichicons but also some purple Sanyo OS-CON 510uf 4 volt according to the label. Unfortunately the product range is not on the label and i also cannot find the 510uf specs in their (older) PDF datasheets/catalogs using google.
        Besides that, i can't find any matching 510uf these days either.
        As a general rule I know you can deviate about 20% max on UF (510uf in this case), but what would/could happen if I were to use 560uf for it, since this cap can also deviate 20% and might have...
        05-30-2021, 12:56 PM
      • Michale32086
        FUNAI/SANYO FW55D25F Shuts Down Randomly
        by Michale32086
        I have Sanyo 55" TV that randomly shuts off..
        Sometimes it will stay on for 5mins or so, sometimes it shuts off after a min or two...
        When it DOES stay on, it works fine...
        All things being equal, would it be more likely a POWER Board issue or a MAIN Board issue???
        Thanx in advance......
        07-12-2022, 12:41 PM
