LG 60PB5600 - No picture
  • mtb604
    • Jun 2016
    • 39
    Reading through the forums, I have so far done the following.
    - Confirmed both fuses on the power board are intact
    - Measured Va voltage on the power board at VA TP initially at ~380V and then drops
    - Measured Vs voltage on the power board at VS TP at 0.0V
    - Searched for replacement Y-Sus boards but everyone is sold out of this board.
    Is there a way to identify which components are bad and replace them on the board?
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 60PB5600 - No picture
    Va should be around 60v
    Are you sure your DMM is working?
    • mtb604
      • Jun 2016
      • 39
      Yes, I just tested it with known voltages.
      • Hamie
        • Apr 2014
        • 1383
        So you're getting 380 dc on the va test point?
        And 0 on the vs test point?
        So if you connect rl-on to 5v stby what do you get?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Shopjimmy do a complete repair kit.
          • mtb604
            • Jun 2016
            • 39
            when I first turn it on, I get 380 vdc at TA TP but then it drops down to 0.7 mv.
            I can find the RL-ON pin, but I don't see the 5V STBY.
            I have
            5.2 V- 17V_DET
            5.2 V- VS_DET
            • cliff_hootarski
              • Jul 2006
              • 411
              Could you please show us where the TA test point is an how you are trying to measure with your meter. VA voltage is usually on the average of 60Vdc. 380Vdc would burn up every board in the set!
              • mtb604
                • Jun 2016
                • 39
                Sorry- 380 mv and then drops to 0.1 mv
                I'm measuring it at the TA TP just above the connector on the lower left of the picture
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Have you checked the fuses on the power supply board. You have 17V, 5.2V, 17V_Det.
                  What voltage do you have for RL_ON, M_ON , VS_ON and VS_Det
                  • mtb604
                    • Jun 2016
                    • 39
                    RL_On: 3V and then a breaker clicks and it goes to 40mv
                    M_On: Same as RL_On
                    VS_On: 0V
                    VS_DET: 5.2 V
                    • mtb604
                      • Jun 2016
                      • 39
                      I only see two fuses on the power supply board and both of them are intact.
                      • Hamie
                        • Apr 2014
                        • 1383
                        So with the z and y-sustains disconnected from the power supply what voltages do you get at vs and va?
                        • mtb604
                          • Jun 2016
                          • 39
                          with both disconnected:
                          VS: 205.5V
                          VA: 54.7V
                          With just the z-sus connected:
                          VS: 205.4
                          VA: 54.7
                          Y-sus is connected to the Z-sus, not directly to the power panel
                          • mtb604
                            • Jun 2016
                            • 39
                            So it seems like it is the Y-Sus that trips the breaker.
                            Is there any way to identify which components on the board have failed or do I just replace everything that comes with the shopjimmy repair kit?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Probably the 30F or 30J type fets are shorted. Disconnect the buffer from the Ydrive and test again.
                              • mtb604
                                • Jun 2016
                                • 39
                                Seems like I will have to remove the Y-sus board to disconnect it from the buffer. I'm having trouble releasing the connectors from the Y-sus board to the buffer. How are they released?
                                • mtb604
                                  • Jun 2016
                                  • 39
                                  Never mind. I got it out.
                                  • mtb604
                                    • Jun 2016
                                    • 39
                                    No voltage measured at VA or VS with Y-Sus connected and buffer disconnected.
                                    I suspect that since nobody has the Y-sus boards in stock that this is a common failure.
                                    • Hamie
                                      • Apr 2014
                                      • 1383
                                      Take photo of the underside of the y-sus.
                                      I've repaired this model a few times and it tends to fail the same way.
                                      • mtb604
                                        • Jun 2016
                                        • 39
                                        Here is the underside of the y-sus board
