Take a look at the pics and see if u think panel or t con? I'm leaning towards panel. Other observation I noticed is the hdmi ports do not seem to be working unless my lappy is being a pia! Lappy couldn't identify all 3 hdmi ports....
Samsung panel failure or t con?
Re: Samsung panel failure or t con?
can't see why it would be a panel although if that's not glare in your picture, then the panel would be a candidate.
odds are high that your pc can't talk to the tv (common problem)... get / borrow a cheap dvd player to verify... or try OTA reception for a picture. -
Nope not glare.....screen is green and osd is red just like in the pictures. I doubt its my lappy as it communicates with the other tvs just fine. But I do have a hdmi blu ray I will try.
So u concur panel? Debating on part out of fixComment
Google it. Try with set in standby, Mute + 1 + 8 + 2 + PowerWilling to help but I'm no expert.Comment
Well they want 50 for a used t con..so in the bin goes. I did try another hdmi decive and ports are working. I did a full serve reset in the service menu, still no good. So by bye..next...LMAO! And there is no one local to service the t con!Comment
Why bin it ? Why not try fixing it ? We can help you diagnose the board lolPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Because its most likely the as15 chip. Thats only 15 bucks. But I cant solder surface mount. I only ever had good luck with through hole. Hands no good with fine work like that. And there is no one around me that can do surface mount.
So in the bin it goes. Cant justify a 50 usd t con board or a 50 usd repair service on a 8 year old set. Parts it is LOL!Comment
Why not try ehy ? Its easy, shame really. But ohh well its your set lolPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Hey Ozzy, send it to me, and I'll give it a go on fixing it. I've got a couple of those AS15's and a hot air station! I'm in OKC, OK.Comment
He probably already trod on the screen or something lol hopefully not.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by triplefourTV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board.... -
by NWArkGuyWell, I will be the first to admit that I screwed up...
In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
I have 2 that I have found and have in my possession. ... -
by KYBOSHI came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
Later I checked for shorts on the panel PCB boards but could not find anything.
When I took a look with the FLIR i noticed the 2 resistors... - Loading...
