Sony Trinitron recap -stay tuned-
  • alessioblaupunkt
    • Aug 2010
    • 50
    Are you interested in a Trinitron Sony 21" chassis AE1B that is going to be full recapped?
    • 30919
    Re: Sony Trinitron recap -stay tuned-
    that's probably a LOT of caps!
    • michael dranfield
      • Jan 2016
      • 232
      • England
      I very much doubt anyone here will know what a CRT TV is .I have been repairing TV for nearly ,40 years now.
      • culcuhain
        • May 2016
        • 186
        • U$@
        I loved my 21" Trimitron when playing games on my computer! That thing is huge and heavy!
        • alessioblaupunkt
          • Aug 2010
          • 50
          Exactly, a lot of caps!
          I'll do the chassis only, not the vertical boards.
          And to be honest, I'll leave the big original elco at the primary.
          All others will be new.
          That sound crazy but it's for a friend.
          Two nichicon PL have eaten 4 square centimeter of copper!
          I told my friend: "You're silly! To reduce a pcb in that condition they must been leaking and smoking since a couple of month! What you're waiting for?
          -stay tuned- elcos will arrive on July 1st.
          • alessioblaupunkt
            • Aug 2010
            • 50
            The old school treasure
            Arrived!
            Let's the party started
            Some elcos to mount in the next hot days
            Stay tuned.
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              It's a good idea . You won't have to worry about re-soldering , because these were some tin to envy .
              I threw one huge AR 25 Last week , probably from laziness . But i kept the boards for useful parts , as usual ..And eventually , i found also the faulty parts . It was moisture destroying the vertical Audio system .
              • alessioblaupunkt
                • Aug 2010
                • 50
                System is now operative but I need the manual because it need G2 adjustment.
                Never done on Trinitron so I need to read before destroying all the work done till now.
                The chassis needed FULL RESOLD, the vertical boards needed PARTIAL RESOLD,
                the CRT pcb needed FULL RESOLD, the small PCB that link chassis to speaker needed FULL RESOLD.
                So: a lot of Sn-Pb (100-150g), a lot of caps, 4*4 square cm routes destroyed by acid (nichicon PL = bye bye copper )
                If it is NOT YOUR TV, don't do it!
                A lot of time, a lot of components, a lot of Sn-Pb (100-150g)
                Stay tuned.
                  • 30919
                  i would have used Sn-Cu
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Please when making such an interesting thread attach the pictures.
                    We hate it when they disappear when the host has a problem.
                    I resized & attached the ones in your previous post...
                    • cmonkey
                      Sony Trinitron KV32FV27 Suddenly Dimmed
                      by cmonkey
                      A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
                      I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
                      I'd say I had it on for about 15 minutes or so and then lugged...
                      04-28-2023, 06:25 PM
                    • motorahead
                      Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                      by motorahead
                      Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                      After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                      10-21-2023, 03:50 PM
                    • ptcriserx3
                      Sony trinitron crt bowed and side color issues
                      by ptcriserx3
                      Hi
                      Ive got a vintage 2001 sony trinitron flat tube tv
                      The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                      See many images attached...
                      Just windering if this is not fixable or something i can correct without getting too invloved
                      Im trying to sell the tv
                      06-17-2023, 07:27 PM
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • sickboy
                      Strange CRT Fault (Sony Trinitron M1410U)
                      by sickboy
                      This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                      11-10-2024, 05:02 AM
