Panasonic TX-P37X20B
  • delphiplasma
    • Mar 2016
    • 23
    Re: Panasonic TX-P37X20B
    Okay...with both SC and SS boards disconnected I get seven flashes. I guess both SC and SC boards are faulty, as cannot get 7 flashes with each board independently connected.
    • delphiplasma
      • Mar 2016
      • 23
      So...I have 2 x boards (SC&SS) ordered from E-bay at a good price. Let's hope they aren't duff like the A board I purchased off E-bay.
      Think I will compare the bad board and good board 'in circuit' resistance of the devices and report back here with them, as it would probably help to know the 'In-circuit' resistances. It's a pain having to de-solder and re-solder components, putting them at further risk.
      • delphiplasma
        • Mar 2016
        • 23
        So, got the replacement SS and SC boards and the TV is now working. I have the original A board fault. Looking at the A board that caused the catastrophe the number is tnph0829 2A whereas the one in the set is the same except for the suffix 1A and a square heatsink. Is there any significance with that? As the A board is hard to find would I be able to use a board from another model set or from the 42/50 model?
        Also, just to let you know there will probably be an SS board for sale soon on ebay for rebuild purposes. I don't think I will list the SC board, as I had modified that board to improve black level.
        I will list the SS board once I compare the semiconductor resistances.
        • delphiplasma
          • Mar 2016
          • 23
          A quick message to say I purchased a new A board, which fixed the original fault. Thanks so much for the help.
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
            11-20-2024, 08:52 PM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • aa10aa10
            Panasonic Toughbook CF-33 mk1 BIOS repair
            by aa10aa10
            Good day,
            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
            01-21-2025, 06:13 AM
          • Mnawar27
            Panasonic CF-H2AU24EF3 bios locked
            by Mnawar27
            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
            I need help to remove it,
            thankyou all.
            SN; 2FKCA26876...
            11-16-2024, 08:00 AM
