Samsung PNC7000 HDMI and Component inputs do not work
  • Ngray27
    • Feb 2016
    • 10
    Hi forum,
    I am having an issue with the TV not being able to recognize HDMI and Component. The TV can recognize that there is something plugged into those ports as they will light up as select able in the source menu. However when selecting an input I have a blank screen and a message that says no signal. I have reset my TV back to factory settings and I have tried leaving it unplugged for hours and the hooking everything back up. I did get a signal for about five minutes after the first time I unplugged the tv but that was it. I am thinking it is something with the Main Board but wanted some opinions first. Perhaps there is a setting somewhere that can fix this?
  • budwich
    • Jul 2015
    • 3097
    Re: Samsung PNC7000 HDMI and Component inputs do not work
    have you checked to see if there is / was a software update done to the set recently. Samsung did have problems with hdmi stuff back late last year.
    • Ngray27
      • Feb 2016
      • 10
      It isn't hooked up to the net for auto updates and I don't believe there has been any updates for this model for quite some time. But perhaps I could try to install the latest one again and see if that would do anything.
      • budwich
        • Jul 2015
        • 3097
        what source are you using?
        • Ngray27
          • Feb 2016
          • 10
          I've got a PVR, Xbox 360 and a Wii U going to HDMI. Hooked up to HDMI 3, 4 and 2 respectively. I tried to update it via usb but that didn't work. the TV did not recognize an update on the flash drive. I am guessing because it is the same version that is already on the TV? I've had trouble in the past getting the ethernet port to work on this TV. Perhaps that was a symptom of a sick Main board?
          • budwich
            • Jul 2015
            • 3097
            the flash has to be format in the right mode. I would think that the unit should at least see the load and ask whether you want to continue but that would be too logical.
            BUT looking at your first post, you indicate it can't see a component signal... what signal are you feeding it?
            • Ngray27
              • Feb 2016
              • 10
              Well it doesn't see HDMI and component but AV/RCA still works as does the co ax cable. So as of now I am running those until I can fix the HDMI. When I test to see if a signal will work I switch between the 360, wii u and the cable box. As for the update the flash drive is Fat32 and I have the TVlausic files unzipped to the root of the drive as the instructions state.
              • budwich
                • Jul 2015
                • 3097
                you might want to try another format.
                Further, with the component input (rgb?), you might want to check your color space settings. They should be set for rgb decoding. Still further, it is strange that an component input indicates "no signal"... have you tried switching you cable "colors" around?
                • Ngray27
                  • Feb 2016
                  • 10
                  It is set on rgb but now that you mention it you're right. Component does get a signal but it's a mix of colors and lines. I can get sound through that one but not a clear picture. I've also tried a few different sources through component to rule out any cable issues. PVR and 360 both do this.
                  • budwich
                    • Jul 2015
                    • 3097
                    ok... that "helps".... further related to this ensure "deep color" is off.
                    Next you say "but it's a mix of colors and lines." what do you mean... Picture? or nothing.
                    Post of a picture this might help. Did you try swapping "colors" (ie. green to blue, blue to red, etc) to see if things change. Further, does the set have a vga input?
                    • Kambi13
                      Samsung LF22T350FHRXEN wont work with HDMI port. Either cant get 1980x1080p resolution, or I get out of range message
                      by Kambi13
                      Hi all I have 2 Samsung LF22T350FHRXEN, working in a dual screen setup. Out of the blue one of them now wont display full resolution trough HDMI port, Either get out of range message or it will be stuck at 1024x768px. Tried reseting the screen, tested different HDMI Cables but with no luck.
                      Need some advice
                      Best Regards
                      04-30-2024, 11:35 AM
                    • dumpstertv
                      HDMI Inputs Have No Signal - Samsung UN65MU6290
                      by dumpstertv
                      Hi all, I have a Samsung UN65MU6290 TV, and it works fine using its internal smart TV functions but I'm unable to get signal from any of the HDMI inputs. The optical audio out works, and there's one other component jack but I don't have the cables to test that. Checking the TV's diagnostics, the "HDMI SW IC" says "NG," so I assume the main board either needs to be repaired or replaced.
                      I saw some mail-in repair services, which I'm considering, but my main question is, if I choose to go the replacement route, do I need *exactly* the same board? There are a lot...
                      01-21-2022, 02:59 PM
                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
                      Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    • aliougm
                      Marantz SR4003 AVR HDMI board issue, seeking for help
                      by aliougm
                      I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                      Connection as below:
                      Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                      If I bypassed AVR then HDTV screen color be good.
                      I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                      3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                      I replaced all...
                      04-30-2022, 12:21 PM
