hi, need advice for half working panasonic 7 blinks p50g10
  • odgaf
    • Apr 2015
    • 36
    hi people first post here
    i got my first project tv a p50g10, it was given to me non working [7 blinks] but by the time i got it home it had come good, it worked flawlessly 4 days then turned off while watching it, 7 red blinks, if i leave it off for a while it turns on fully and may last 5 minutes, if i try to power cycle, it boots, backlight comes on for 3 seconds and then it turns off,
    what would cause this intermittent behavior??. poor joints ? obviously nothing has blown as the tv is semi working and the signs point to powersupply/ysus/buffers so my question is, whats the best way to troubleshoot before getting the multimeter out, and also does this tv allow me to disconnect the cards to try and isolate the faulty one, ive been tempted to try it but have read you can blow cards on certain models
    can anyone talk me through the first stages of troubleshooting and isolating the boards please, this is my first repair project im pretty nooby at electronics but im learning fast
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • Biruslapio
    Panasonic P58V11B 8 and 12 blinks error "fix"
    by Biruslapio
    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
    04-13-2021, 07:13 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • Alicat
    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
    by Alicat
    Stopped by this site trying to fix my parents Panasonic Plasma TV.
    Model number is TH-50PZ85U
    Power comes on and the red power light stays on solid.
    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
    I also hear a few clicks.
    I also think my parents said there was a thunderstorm and the TV failed after that.
    Section 6 in the service manual talks about power and no screen,...
    10-30-2024, 10:09 AM
  • CrewmanRedShirt
    Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
    by CrewmanRedShirt
    Hello all,
    As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
    07-13-2024, 11:02 AM
