Samsung PS50C450 picture issues
  • jczarniak
    • Oct 2015
    • 179
    I'm not sue how to describe my problem.
    When changing channels, picture from previous channel stays on, still slightly visible,mainly channel logo on bright background.
    Menu outline still visible after leaving menu etc...
    When no signal (black background) kind of dark red patches on the screen.
    Which screen board (if any) should I change to fix it.
    Thank you.
    Regards.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung PS50C450 picture issues
    Post pictures of your boards and screen fault if possible.
    • jczarniak
      • Oct 2015
      • 179
      y-sus:
      LJ41-08458A
      buffer:
      Lj41-08459A
      It will be difficult to capture the picture fault.
      Darker shapes (shadows) on the bright background or dark red patches on the black screen (when no signal)
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Have you tested that all the voltages match what they say on the panel sticker one maybe a little low causing this isuue and its nice to see a new member close to me not many of us on badcaps.net in warwickshire.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          As vinceroger69 suggests, the panel should have a label which gives various voltages which you will find on the circuit boards. VS, VA, etc. Do the voltages read from the circuit boards match?
          • jczarniak
            • Oct 2015
            • 179
            Wow I'm from Bedworth, a few miles to Nuneaton
            I checked the Vs and Va on power supply.
            I already increased the voltage by a few volts. Nothing changed.
            • diif
              • Feb 2014
              • 6978
              • England
              The review here mentions the TV suffers from image retention issues.
              https://www.avforums.com/review/sams...-tv-review.124
              Leicester here
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                i wonder if they ever did a software/firware update to help sove this issue i guess if this panel has a good few hours on it its going too be hard to get a good image etc.
                • jczarniak
                  • Oct 2015
                  • 179
                  Hello to Leicester !
                  So you think, that my screen is ageing and there is nothing I can do?
                  • jczarniak
                    • Oct 2015
                    • 179
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      maybe but wait for more experienced members to chime in they may have other thoughts, i dont often have plasmas to work on but still read all the threads for when i do image retention is something im not sure on myself but as you have already put the voltages up a little im not sure what else you can try.
                      • jczarniak
                        • Oct 2015
                        • 179
                        Thank you very much.
                        Let's see if there are some other opinions also.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          in the mean time take some good clear pictures of the boards used in your set as some members if theres no pictures wont offer help which i dont blame them as we dont have the tv in front of us we rely on the pictures provided these boards may also be used in another set we reconise.
                          • jczarniak
                            • Oct 2015
                            • 179
                            Good tip.
                            I'll try to take some tonight.
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              Measure the Ve - Erasing Voltage generated at the X-Board and derived from the Vs voltage. Ve is 95-100Vdc. Primarily used to assist the Y-Board in erasing previously activated cells and neutralizing the erasure before the next scan.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Leicester here
                                Interesing review. Would go along way to answering one of the issues.
                                • jczarniak
                                  • Oct 2015
                                  • 179
                                  Very interesting.
                                  I'll measure tonight.
                                  Thanks a lot.
                                  • jczarniak
                                    • Oct 2015
                                    • 179
                                    Is there test point on x-board to measure Ve voltage, please?
                                    If not, how can I measure it.
                                    Thank you.
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Yes--Its marked, Ve. There's a small pot near the TP for setting.
                                      Worth checking VSC on the Y and that the Vs is correct.
                                      These panels at this age also show poor discharge especially when cold showing up as a grainy picture--like its projected on black sand. Nothing much you can do about that, its just age related Mal-Discharge.
                                      The IR you're experiencing seems also related to age when all voltages are correct, Prolly one of the poorer samsung panels the worst being the E series...
                                      Oddly, the 42" C isnt half as bad, Dunno what they did wrong on the 50"
                                      TELEFIX
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        Let's see...The Y- Main Board is the left board and the X-Main Board for Samsung Plasma TVs is the board on the right, if looking at the TV from the back. So there should be a Test Point labeled Ve somewhere on the X-Board. Loss of Ve will cause the symptom you are having. For a quick fix replace the X-Board.
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
