Another Panasonic TH-50PZ80U Plasma with no picture no sound no blinking error
  • unknown_hunter
    • Jun 2016
    • 8
    I am working on a TH-50PZ80U (01/2009 build date).
    I receive this in its current state. It is not mine. I was told after a bad thunder and lightening storm it would not display a picture but you could here the relays click. I was also told that there was a cable box plugged into it and that was also toast after the storm. I assume that lightening is the culprit.
    When I plug it in I can hear the click of the relay. Then I can either push the power button on the remote or the TV and the red power light will come on and you can see a slight glow to the screen. When I hold the power button the tv will then turn off and then turn back on again by itself.
    After much reading on here. I pulled the back cover off and did not see any obvious bulging caps or burnt marks.
    Other than this mark in the upper left corner.
    When I pull the LVDS cable on the A board I get an all white screen.
    I thought this would indicate a bad A board. (TNPH0721ALS) So I ordered one from ebay and installed it. I confirmed that I had the AL version of the board. Same problem still exists. Do I need to activate the new board?
    I have green LED's lit on both the SS and SC board. All fans run when power in on. I have 189.8volts DC going to both.
    Any thoughts on what I am missing or where to start next?
    Thank you.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Another Panasonic TH-50PZ80U Plasma with no picture no sound no blinking error
    you received a dead A-board by the sound of it.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • unknown_hunter
      • Jun 2016
      • 8
      Thanks for the reply Martino!
      Is it possible to have a bad D board?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I agree with Martino.
        • unknown_hunter
          • Jun 2016
          • 8
          Thanks for the reply ReeceyBurger123!
          The display does not illuminate. I did try to enter the service menu and no luck.
          I will try to get another A Board and report back. Unless someone on here has any other suggestions?
          • unknown_hunter
            • Jun 2016
            • 8
            I wanted to give an update. The first A board I purchased from Ebay was DOA. Which of course you don't find out until its installed. The 2nd board was GTG!
            Thank you everyone!
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              thanks for the update!
              Where you able to get a refund on the doa board?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Awesomeness
                • unknown_hunter
                  • Jun 2016
                  • 8
                  Yes I was. Any of the boards that I purchase from Ebay I make sure the buyers accept returns, even if I have to pay for return shipping.
                  Has anyone successfully repaired an A board at the component level from here? I see there are services out there but I was just wondering if anyone on here has.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Probably needs a reflow of the cpu etc.
                    • hugocarmo
                      Panasonic TX-24A1UN CRT Sound and Input problem.
                      by hugocarmo
                      Hi.
                      IΒ΄ve been given an old CRT from Panasonic, itΒ΄s almost new, it was storaged and almost not used since bought.
                      It is imaculate inside, almost no dust or debris inside.
                      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                      So I started to look for a service manual, I found one, and started from the beginning.
                      Most of the times the caps are the problem so I orderer all the caps for all boards,...
                      04-26-2025, 07:45 PM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • Audeze
                      Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                      by Audeze
                      I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                      Does...
                      10-06-2024, 08:54 PM
