Sharp LC-42SB48UT-a no standby voltage
  • jts1957
    • Dec 2008
    • 38
    #61
    Re: Sharp LC-42SB48UT-a no standby voltage
    Originally posted by dick_barton
    Service manual attached with power supply schematic, hopefully
    Be sure to look at 42", there is also a 32".
    AcGeorgiegirl: 1st attachment wrong PS.
    • AcGeorgiegirl
      • Jun 2013
      • 202
      Here are the PFC & Key Diagram, too.
        I got it from ELEKTROTANYA and it does not match the OP diagram. See post 57
        • AcGeorgiegirl
          • Jun 2013
          • 202
          Originally posted by budm
          You have the schematic?
          OK, I download the service manual from ELEKTROTANYA.
          My manual show TNY277, your manual shows something else.
          Please look at what is actually printed on top of the IC903.
          Where did you get the manual from?
          Yes, it is printed on the ic as TNY277. My manual, pretty sure, came from ELEKTROTANYA. I'll post the manual here, too, if that helps.
            OK, your manual does not match your TV version.
            The one I download is the 'A' version and seem to match your power supply board picture.
            But any way, it uses TNY277 none the less, so I still suspect the parts in the feedback regulation circuit.
            Try having the main board connected to the power supply board to see if it will go up to 5V in case the circuit does not like to work without the load.
            • AcGeorgiegirl
              • Jun 2013
              • 202
              Yes, that's it, then, BUDM! Mine didn't have the "a" after model code, but I just looked again, and it's the one that I get from my search on ELEKTROTANYA.
                Originally posted by AcGeorgiegirl
                This is weird. ELEKTROTANYA is the only site that I've found that has the manual free, and I'm pretty sure mine came from there. Don't know if it matters, but my model has "A" after the name, and the manuals don't.
                There are two manuals at ELEKTROTANYA, the one I downloaded is for the 'A'.
                • AcGeorgiegirl
                  • Jun 2013
                  • 202
                  I am so sorry for causing all this confusion, while you guys are trying to help me. My translation app for Elektro- apparently mussed up my search, without me noticing. The "a" was left out.
                  • AcGeorgiegirl
                    • Jun 2013
                    • 202
                    I tested with psb connected to the main, and got a fluctuating voltage from around 2.8 to 3.8 or so.
                      OK, so it cannot even maintain the regulated 5V output.
                      I would try replacing C969 in the primary side and the 4 cap in the cold side by the connector that goes to the main board.
                      • AcGeorgiegirl
                        • Jun 2013
                        • 202
                        So it lookds like you meter is OK.
                        There are parts that are used for regulating the output of the 5VSTBY:
                        IC913 (Vref diode xx431??, IC911 (OPTO), Voltage divider for the IC913.
                        The IC's you suggest I test...can you give me some guidance on how to do this, if other than removing them completely from the board?
                          The IC is kind of working because you do have output Voltage, just not the right level as needed, there really no 100% test to verify that it is good or bad. You can try replacing it but I would try replacing the cap first.
                          This IC when it failed, it usually blew up badly due to shorted out internal Power MOSFET.
                          • AcGeorgiegirl
                            • Jun 2013
                            • 202
                            Ok. You mention one IC....are you referring to the IC913? What about the IC911? And by "voltage divider" for the IC913, are you meaning a voltage regulator that I should find to check?
                              I am referring to the TNY277 IC.
                              • CapLeaker
                                Leaking Member
                                • 8130
                                He means IC903 (TNY277)
                                • AcGeorgiegirl
                                  • Jun 2013
                                  • 202
                                  Ok. I mistook your previous post(I quoted it above) as the area you are now referring to. So, which cap to replace? Is it c969(one closest to TNY277), or do you mean the filter cap?
                                  • CapLeaker
                                    Leaking Member
                                    • 8130
                                    change c969 first.
                                    • AcGeorgiegirl
                                      • Jun 2013
                                      • 202
                                      Replaced C969. No change.
                                      • CapLeaker
                                        Leaking Member
                                        • 8130
                                        Did you check the ESR of C955 and C934? What DC voltages do you get on all the pins of IC903?
                                        • AcGeorgiegirl
                                          • Jun 2013
                                          • 202
                                          I don't have an esr meter, so I can't test the caps. The IC reads .06 on pin #4(the Mosfet drain connection). All others are between .04 and .05 BUT these are a negative(-) number. My DMM is set on 20 dc volts.
                                          • x_orange90_x
                                            Samsung UN55KU6300F no standby voltage
                                            by x_orange90_x
                                            I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                            Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                            05-21-2025, 09:59 PM
                                          • Bad_IC
                                            Philips TV 37pfl5604h/12 no standby voltage
                                            by Bad_IC
                                            I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                            These are the voltages in some pins of IC fsq510:
                                            Vcc=18v
                                            D=320v
                                            Vstr=154v
                                            Unfortunately, I couldn't find the schematic
                                            What else could I check?
                                            Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                            Thank you​...
                                            11-08-2024, 01:07 PM
                                          • brock-s
                                            Asus GL503GE 3.3 standby voltage low
                                            by brock-s
                                            An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                                            Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                                            Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                                            07-13-2023, 03:43 PM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Ritchie_Uk
                                            Sharp 32BC2K0 Service Manual of Fix Please?
                                            by Ritchie_Uk
                                            Hi Folks
                                            I am searching for a Sharp 32BC2K0 Service Manual
                                            Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
                                            Fault - Coloured "Bars" very thin all across the screen.
                                            I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
                                            I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
                                            Is there such thing as a Boardview for this TV?
                                            I will Post the Photos in a second
                                            Stay Safe !...
                                            09-05-2024, 06:35 AM
