PS42C7 Hd Vs Does Not Shutdown Fixed
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Got this older 42" Samsung here, I recently recapped the set as it had some bad ones, which sorted the mass amounts of mal-discharge on the screen. However even after pressing the off button the Tv doesn't shutdown properly and the PDP stays primed up.
    The motherboard and Tcon turn off (you can hear the melody going off and the standby light comes on) but the screen stays primed up. Found Vs and Va to be up constant for some reason. Vs on always on for some reason even when the rest of the set is in standby which it should not be.
    Simple fix, the 5.3v adjustment pot was turned up all the way to 8v, after turning it back down to 5.3v exact the set turns off and all voltage rails collapse when the set is put into standby and the screen goes off.
    Odd one here but sorted, there was no sign of the owner tampering with the set either so that was odd how that happened. Video of the recap coming soon.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: PS42C7 Hd Vs Does Not Shutdown Fixed
    How much Vs does the t-con board take? Does mal-discharge really go down much on a LCD panel if you repair the caps on the Va line?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      The caps failed were not for the VS rail they were for the lower voltage ones. When they fail more ripple is sent to the controllers etc so they then send more ripple to the susboards which messes up the drive waveforms. The VS rail uses bulk DC caps at low UF which is better for the ripple.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        lol
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Shit I just realised what you did hahah I dont know why you posting here somthing fishy hep lez people go with lez repair dosnt worth to write much more for such suck gay over here keep your ass fuck off snf my post
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            Get's even funnier as you now admit it took you this long to function on it,bahahahahahahaha.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hahaaaaa lol at first I just replied as I thought you read the thread wrong then today I re-read it and made sence lolol learn to respect other to earn other respect do put not your ass between other talking dont ever quote my name again
              • cruiser_
                A1466 820-00165 intermittent shutdown
                by cruiser_
                hi there,
                Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                Gives shutdown cause -128.
                Seem to work fine in SMC bypass.
                Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                Observations:
                - SMC_RESET_L - when pulled down - plug goes orange/green and...
                10-11-2022, 12:06 PM
              • howardc64
                Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                by howardc64
                TV was fixed just after removing Samsung's rear snap cover.
                This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                Maybe PSU->backlight connector didn't have a good contact?...
                07-23-2025, 12:34 AM
                Richtek RT8205A RT8205B RT8205C Power Supply Controller for Laptop Computer Datasheet
                The RT8205A RT8205B RT8205C dual step-down, switch-mode power supply controller generates logic-supply voltages in battery-powered systems. The RT8205A/B/C includes two pulse-width modulation (PWM) controllers fixed at 5V/3.3V or adjustable from 2V to 5.5V. An alternative LGATE1 output LG1_CP can be used for external charge pump (RT8205B). And an optional external charge pump can be monitored through SECFB (RT8205C). This device also features 2 linear regulators providing fixed 5V and 3.3V outputs. The linear regulator each provides up to 70mA output current with automatic linear-regulator bootstrapping...
                10-23-2024, 03:37 AM
              • RATIM SIDDIQUE
                hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
                by RATIM SIDDIQUE
                automatic shutdown after 30 sec of display coming
                do not shutdown without ramstick
                someone give me idea plz
                08-20-2024, 03:50 AM
              • ronelex
                Acer MS2304 Shutdown when HDD or ODD Present
                by ronelex
                Model: Acer MS2304
                Board Code: 09920-2
                Issue: Unit Powers On with Display Without HDD or ODD attached
                When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
                Unit wont shutdown when ODD or hdd attach if no ram is attach also
                I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
                05-15-2021, 01:28 AM
