LG Plasma panel lines
  • Fleckers tv
    Fleckers TV
    • Nov 2015
    • 89
    Sorry not Plasma LED edge backlit
    This is supposed to be the LG NO SIGNAL picture but its just scrolling lines, at first I naturally assumed panel fault ,but there is this niggling doubt in the back of my mind.....
    when I unplug the Tcon from the main board its just a plain normal backlit picture (obviousley) so does anyone else thinks its Panel ?
  • Fleckers tv
    Fleckers TV
    • Nov 2015
    • 89
    Re: LG Plasma panel lines
    model attached
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      If you unhook one of the Tcon ribbons to the panel and see if you get a clear picture then reconnect and repeat for the second ribbon.
      Edit.
      How many ribbons from the Tcon to the panel does it have. Googling appears to show 2 Tcon boards. One with 2 ribbons and one with a single ribbon to the panel.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Mate you even said it yourself the panel is toast.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          11-18-2025, 02:09 AM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • mmartell
          General Questions on the Relationship Between Mainboard, TCON and Panel
          by mmartell
          My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
          I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
          And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
          01-06-2024, 01:32 PM
