Model: Samsung UN46D6050TFXZC
Version: H301
Mfg Date: October 2011
SMPS: BN44-00423a
Board Front Pic
Board Rear Pic
Ok I need help!
Background;
Watching TV few nights ago, 2min left in my show of course, and TV goes black. Remote won't turn it on, power cycle no luck, nothing.
Power LED flashes twice, five times then pause and repeat. (Why have blink codes if they're not useful?)
I recalled Samsung doesn't have a great reputation for capacitors, so first thought was check for any that were popped. I saw one slight bulging, and another that was questionable, so replaced them both. No change.
I'm not a hobbyist for repairs, but I'm more then comfortable doing this kind of repair. So off to Google!!!
So that's how I found this forum with it's dedicated members and loads of information.
Doing some searching, I found this;
Fast Track Guide
Did the backlight test, no backlight. My DMM didn't have a capacitor test mode, so I decided I wanted to see if I could fix this myself, I bought a new fancy DMM for my workbench and kept inspecting the board. Ends up the replaced caps were fine?!
What I've Done;
There's no signs of cold soldier joints, anything blown or discoloured. Fuses are fine.
Found a repair kit, so I'm using that as a means to start troubleshooting.
Managed to find the schematic, although some notes are in Spanish.
RM807 is fine.
Both transistors passes a simple diode test.
Bridge rectifier passes a simple continuity test. Gets warm while board is plugged in.
Board Tests
CP814S - 393v
CM813 - 22uF
CNM803a
p16 - PWR ON/OFF - v3.3
p15 - B5V - 0v
p14 - A5V - 5.31v
p13 - B5V - 0v
p9 - Vamp - 10-25mV
p8 - BLE_ON - 0v
p7 - Vamp - 15-35mV
p5 - B13V - 0v
p3 - B13V - 0v
So I have standby power at least!
I went on to test the other ICs from the repair kit but wasn't getting any source voltages that would turn them on.
The FET that would provide 5VB, no voltage reading at CM875. Figured it wasn't getting the input 13v.
No 13v reading from CM858 or CM859 (both caps good), so the winding from the transformer isn't giving output.
This is where you come in;
I feel like the power transformer isn't working, but the labels aren't helping to find a schematic breakdown, or even a replacement order part.
If there's more that I can troubleshoot, I'm all ears.
I borrowed the bedroom TV, and I'm only in the hole for some caps and a DMM (but I don't count that). I'm having fun troubleshooting, but definitely not opposed to clicking "Buy Now" off eBay if it isn't fixed in the next week or two. My heart tells me I'm $5 and a Digikey order away from fixing this! May consider a "finders fee" too
-Matt
Version: H301
SMPS: BN44-00423a
Board Front Pic
Board Rear Pic
Ok I need help!
Background;
Fast Track Guide
What I've Done;
RM807 is fine.
Board Tests
CP814S - 393v
CM813 - 22uF
CNM803a
p15 - B5V - 0v
p14 - A5V - 5.31v
p13 - B5V - 0v
p9 - Vamp - 10-25mV
p8 - BLE_ON - 0v
p7 - Vamp - 15-35mV
p5 - B13V - 0v
p3 - B13V - 0v
-Matt
