Looking for flash from Grundig vision 4 32 (YCA190R-4)
  • atsio
    • Oct 2013
    • 819
    • Greece
    Looking for flash from Grundig vision 4 32-4801 mainboard YCA190R-4 (probably the same with YCA190R-3) ic winbond 25x80avsig.
    Thanks in advance.
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Looking for flash from Grundig vision 4 32 (YCA190R-4)
    Anybody?
    • LEECH666
      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
      by LEECH666
      Good day ladies and gentleman!
      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
      01-19-2024, 05:46 PM
    • spmetroil
      Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
      by spmetroil
      I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
      The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
      I have a CH341A programmer and I already attempted the following steps:
      1. Identified the correct chip (W25Q128, 3.3V SPI flash).
      2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
      3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
      08-19-2025, 09:23 AM
    • Vincent Kahle
      Winbond 25Q16JWNIG – Asus ROG Strix Scar 18 G814JZ bricked after wrong flash – Need help
      by Vincent Kahle
      I hope someone can help me.
      I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
      Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
      I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
      A valid BIOS/EC backup...
      06-05-2025, 09:27 PM
    • ekozeko333
      by ekozeko333
      🧠 What I’ve Done So Far
      Flashed...
      06-21-2025, 02:48 AM
    • corrize
      Nikon D800 camera - flash don’t work and capacitor don’t charge
      by corrize
      Hello, I'm stuck in troubleshooting…
      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
      10-01-2022, 10:02 AM
