Insignia NS-LCD47HD-09 Stuck in Stand by
  • LLLlllou
    • May 2011
    • 201
    Re: Insignia NS-LCD47HD-09 Stuck in Stand by
    Originally posted by culcuhain
    it fit perfectly in all 5 holes
    That's what she said!
    Sorry, couldn't resist.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      #42
      lmao!
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
      • DXseekerMO
        Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
        by DXseekerMO
        Hello everyone!
        Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
        Symptoms:
        1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
        2) TV does not appear to turn on
        3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
        4) "Power on" terminal on Power Supply has 3.26v
        5) "A13V" terminals have 12.9v
        6) Stand-by test jumper on Power Supply has 12.9V
        7) Optical audio jack on Main Board illuminates
        8) With stand-by...
        06-09-2021, 12:19 AM
      • Biruslapio
        LG 42PX4RV stuck in Stand-by
        by Biruslapio
        I'm now in possession of this very old 2005 plasma TV, the original failure described to me was that it only turned on after hundreds of attempts, eventually it just stopped working.
        It has stable stand-by 5V and 4.4V AC-ON voltages, the main board red LED lights up, it has all of the secondary voltages generated by standby: 3.3V, 2.5V and 1.8V. Trying to power on via remote or power button does nothing, the signal is received, but it's stuck.
        The power button was bad, replaced but that did not fix anything, replaced 10V 1000uF, 25V 470uF, 50V 47uF and 50V 10uF capacitors...
        08-25-2021, 04:28 AM
      • stormanimal83
        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
        by stormanimal83
        Hey....
        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
        01-18-2024, 02:15 PM
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
