Panasonic TX-37LZD80 - Tcon Fuse Blown
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Hello All,
    I ordered a replacement Tcon for this set which arrived today and on checking prior to installation, found the 1.6A, 24V smd fuse was open circuit. The fuse is markesd as “162 NCC” and some information can be found at the following site.
    https://cdn.badcaps-static.com/pdfs/...6e726ed899.pdf
    After checking for any shorts on the board I powered up the set and used an external power supply with current limit set to power the Tcon.
    The set appears to be working fine. The photo is for an identical Tcon.
    Does anyone know where I can obtain a replacement smd fuse for it.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TX-37LZD80 - Tcon Fuse Blown
    Off the old T-Con....?
    TELEFIX
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Hello Alastair,
      It was because I found the blown fuse on the original TCON along with other problems with it that I decided to check the replacement Tcon prior to installing it. So unfortunately that option is not available to me.
      • R_J
        • 9535
        something like a 1.6 - 2.0 amp rating 32 volt or higher voltage, something like this ?
        http://www.digikey.com/product-searc...=0&pageSize=25
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Thanks RJ,
          After a frantic search I found some semiconductor fuses amongst my very old stock of components. It's higher rated but hopefully OK. It doesn't get in the way of the Tcon cover and sits in nicely. The device fitted was an ICP-NP50, 2.0 Amp
          Thanks to all once again for your help.
          • triplefour
            Samsung UN55ES7003 has blown fuse on TCON and short to ground.
            by triplefour
            Samsung UN55ES7003
            made house call.
            red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
            psu has self test feature.
            disconnected from mainboard.
            determined PSU ok BL ok.
            suspect mainboard.
            disconnecting tcon has no change on operation.
            markings on mainboard:
            BN97-06531P 0151
            BN94-06123R
            found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
            for 54$
            second house call:
            with replacement mainboard, tv turns on, has sound,...
            07-13-2022, 03:53 PM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • beetle1303
            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
            by beetle1303
            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
            01-13-2025, 08:49 PM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
