Broken RCA L40FHD41YX9
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I have an RCA L40FHD41YX9 that isn't working. I tore it open and two caps were physically buldging on the PSU. I replaced them and a good cap with some Panasonic FR series caps. I thought maybe that'd fix it. I hook up a video signal and I get nothing. It's like the backlighting isn't kicking on. I see a wire going to the inverter board that has a bunch of pins. A good amount of them in a row are labeled 24v, the other ones are labeled (in a row) gnd. The 24v's all seem to check out and measure around 24v. I pulled the cover off the inverter and checked the four caps. They seem okay.
    Does anyone have any suggestions on what I should check? I can post nicer pictures. I was just hoping someone might be familiar with this system and just be like oh, you should check the blah pins and see if you get blah voltage, if not, check the blah and see if it's broke!
    Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    Re: Broken RCA L40FHD41YX9
    So you have 24V to power the inverter board, now you need to find if it is getting the BL-ON from the main board.
    • Spork Schivago
      • Mar 2012
      • 4734
      I knew it! Thanks Budm! So, I'm going to show pictures of the main board and maybe you can help me figure out which signal is the BL_ON. I had found where it was listed on the silkscreen or whatever it's called but I couldn't figure out which pin it actually was.
      It's hard to see, but on this pin, on the PSU, there's actually two layers. I'm sure you know that though. I can't figure out how the labeling on the board goes. Is it the pins in the back or the pins in the front? If that doesn't make second, I can try to explain more with more pictures.
      • CapLeaker
        Leaking Member
        • 8180
        Measure the DC V of BL_ON.
        • Spork Schivago
          • Mar 2012
          • 4734
          Right, but which pin is the BL_ON? I tried that last night but there's a back row of pins there. And I can't figure out if it's the front row or the back. The printing on the board isn't exactly clear there.
            May be it will be easier to see if there is label on the inverter board.
            • Spork Schivago
              • Mar 2012
              • 4734
              Besides the connector that has the 24v and GND connections, there's a 4 pin wire on the inverter. It lists four connections, SYNC, N.C, N.C, GND. Would that be it?
              For the main board, I can measure the front pin and the back. Maybe we can assume because BL_ON is listed last, it's going to be either the last pin in the front row or the last pin in the back row there...
                Can we see the pictures of the inverter board? Is there more then one connectors on the board?
                  https://www.badcaps.net/forum/attach...9&d=1464795581
                  P5 BL-ON.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    Originally posted by budm
                    Dang, I was looking at the wrong one! I thought for sure the other one that had the BL_ON it was it. I thought the words were just mashing together.
                    I measured it, 4.01VDC.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Do you still want pictures of the inverter board? I'm thinking if it's getting the 4.01V BL_ON, then maybe the inverter board isn't working right. What do you think?
                        Since you have BL-ON then we do need to see the inverter board and also the whole backside of the TV that shows all the boards.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Them bad caps probably blew the fuse on the inverter. Get us some images of the inverter please.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            Do you guys still want pics of the boards? ReeceyBurger123 was right. I didn't think any fuses would be on the inverter board but sure enough, two 1808 SMD 125V 7A and one of them has infinite continuity. I'm going to order a couple.
                            Should I replace them and then test it or keep testing stuff and when I get everything tested, place an order?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Possibly shorted mosfets too. Can we have images please ?
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                I found a 125V 5A, same make. Could I temporarily use that to test the inverter and see if it fixes the TV? And if it does, just order a new replacement and nothing else? Or would that be a bad idea?
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Here's some pics...it's a bit awkward to take pics of this. I can send zoomed in clear pics of any area that you guys want. Just let me know if you want anything special.
                                  The way it goes is the first five go together, they make up the whole board. Then you see one part of the back, where it looks really burnt. Then you see the front area, around where the burned mark would be, if the burned mark was on the front...
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    I wanted to apologize for not responding right away. We're in the process of looking for a house to buy as well. So when I'm waiting for a response, we start looking and then we forget! I hope that's okay. I don't want you guys to think I don't appreciate your help.
                                      Get the new board:
                                      http://www.shopjimmy.com/catalogsear...CA+L40FHD41YX9
                                      That burnt mark is the clue, it is another of those SAMSUNG board,
                                      Samsung LJ97-02098A
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        Get the new board:
                                        Samsung LJ97-02098A
                                        They're out of the Samsung LJ97-02098A but they have a rebuild kit, which I don't really want. Can I use the LJ97-02098B? They're out of the 02098B as well. They also sell a repair kit for that. I'd like to know so I can check on other sites. Thanks!
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                        • Powderfanupnorf
                                          Dell AL440LX power on switch circuit help required
                                          by Powderfanupnorf
                                          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                          06-24-2024, 01:24 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • FeerBaron
                                          Got in way over my head with Supermicro server board and upgrade.
                                          by FeerBaron
                                          Last year I bought a server. It's worked fairly well but had some issues. Some pcie slots didn't work and Xeon v4 is a bit slow and missing AVX 512. Came to realize that the next version up, with skylake uses mostly the same chassis.
                                          A board popped up on ebay one day being sold for parts. A working board like this is over a grand at best. This particular one was about $125 and I decided to gamble.
                                          At first it seemed simple enough. According to the description it looked like some mechanical damage.
                                          Found the missing 560uf cap and thought I was...
                                          Starts
                                          01-26-2024
                                          Ends
                                          01-26-2024
                                          01-26-2024, 06:36 AM
