Toshiba 42rv530u wont power on
    Re: Toshiba 42rv530u wont power on
    Originally posted by Heavyarms92
    Ok, so if I am understanding everything correctly. SR81 seems to be the main suspect here. I will check all 4 pins next.
    Also, everytime I check R850 all I get is 0 ohms. I know I should get 1.8 though. I will more than likely unsolder it and check it to be sure. If that's wrong correct me, there may be a trick that I haven't learned yet, or just poor technique on my part.
    What Ohm scale were you using? What does your meter show when you touch the two meter probes together, that will be the lowest resistance you should see unless your meter has ability to ZERO out the meter probe to get the meter to show 0 Ohm.
      • 12332
      • U.S.
      #42
      Originally posted by R_J
      It is not going to be the lagre cap, many times they look bulged but it is just the plastic top that is bulged a bit, if you can press it flat the cap is very likely ok.
      If R850 is open it is caused by bad contacts on relay SR81 in standby low current flows through the resistor, when the tv is turned on the relay shorts the resistor so the higher current bypasses the resistor, If the relay contacts are bad, as in open, ALL the current flows through the resistor, it heats up and opens its internal fuse.
      This is a very common problem
      Ok, looks like he needs to replace SR81.
        • 12332
        • U.S.
        #43
        Just for curiousity would the board below be compatible? It is for my television but not the same board number. I don't think it would fit but it might. Safety is my primary concern though.
        https://rover.ebay.com/rover/0/0/0?m...2F273236805950
        Yes that is a match, you could try replacing SR81, that won't cost more than a few bucks.
        • Heavyarms92
          • May 2018
          • 62
          You don't need to unsolder R850, if it is good it would read close to a short (1.8Ω) , the relay should be replaced or taken apart and at least clean the contacts (this cant be checked with your ohm meter)
          SR81 has 4 pins, two are for the coil and 2 are the contacts, the 230Ω is likely the coil resistance.
          I believe the coil is consistently giving me 267 ohms, and the contacts are at 0 when checking capacitance. Am I doing anything wrong? I've checked on AC and DC.
          • Heavyarms92
            • May 2018
            • 62
            I'm using an older Simpson 467E, and it measures 0 when I touch the two leads together on AC and DC for capacitance. The leads on my little read harbor freight multimeters ripped themselves off of their respective wires when I picked up the unit on 2 different occasions. I'm not sure how to crimp them back on...
            • Heavyarms92
              • May 2018
              • 62
              I will try that. If it pops will that mean I need to go back to the bridge rectifier? It checks out per the TampaTech video that I've watched regarding Toshiba Tvs. It measures between 400-600 ohms consistently when checking capacitance.
              • R_J
                • 9625
                It a RELAY not a capacitor! A relay is basically just a switch activated by a coil.
                • Heavyarms92
                  • May 2018
                  • 62
                  The components at this position appears to be a switching relay. The component reads GEC C183 TYPE DG1U 12VDC III coil 12 volt 8A 250V 8A 30V. I have tried to google a replacement but I have had no luck.
                  • Heavyarms92
                    • May 2018
                    • 62
                    Ok, so should I be checking Voltage and not Ohms? Sounds like it should be 12 Volts, but it's not plugged in.
                    • R_J
                      • 9625
                      To check the resistor you put your meter in ohms, in the lowest range and place the probes across R850. It should produce the same reading as if you connected the probes together. The reading should be near 0 (actually 1.8Ω)
                      If the resistor R850 is open it is because the relay contacts are bad. The contacts are burnt. The problem is not with the relay's coil
                      Because the resistor is open you will not have any standby voltage.
                      • Heavyarms92
                        • May 2018
                        • 62
                        Ok, so if I unsolder it and resolder it you think it will go? When I tested it earlier it was 0 ohms, would that mean it was open? I need to get some flux then, I think I am out unfortunately.
                          0 Ohm = Resistor has NOT gone open circuit.
                          What kind of spare parts do you have? Do you have any resistors?
                            Meter user manual: https://cdn.badcaps-static.com/pdfs/...6d86336230.pdf
                              BTW, I would like to suggest you to plug the TV into GFCI outlet to protect yourself, and do not touch anything on the power supply board while the TV is plugged into the AC outlet.
                                SR81 12VDC RELAY: see post #15
                                https://www.badcaps.net/forum/showth...highlight=SR81
                                • Heavyarms92
                                  • May 2018
                                  • 62
                                  Honestly none, I will have to order some, I was just trying to figure out what I needed and where to start. I have done some electrical work but not much with pcbs. This is a new frontier for me.
                                  I do have a 12v power supply though. I have no idea how to use it but I have seen guys testing things with them.
                                  • Heavyarms92
                                    • May 2018
                                    • 62
                                    I will make sure to use one of these, I don't like the idea of getting shocked.
                                    • R_J
                                      • 9625
                                      So now the resistor R850 is NOT open? If it measure 0Ω then your fault is somwhere else
                                      with power OFF, check the rsistance of the fuses F820 & F840.
                                      If you feel comfortable working on this with power applied...
                                      Measure the DC voltage accross C820 (220uf/450v) If there IS voltage is it 160v or closer to 400v?
                                      Keeping your negative probe on the (-) of C820, check the voltage on both sides of the fuses, F820 & F840. IS there voltage on both sides of these fuses
                                        • 12332
                                        • U.S.
                                        #59
                                        Ok, so whats the status of the filter cap, bulged or flat?
                                          • 12332
                                          • U.S.
                                          #60
                                          Did you test the bridge rectifier and voltage regulator?
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
