Vizio E701Ia3 main board question (pics attached)
  • T3xasa22a22in
    • May 2016
    • 11
    • Usa
    Ok so im trying to get an issue solved here, or at least get some clarification on a part. The e701ia3 i have has a main board with the model bumber of an e601ia3 on it. Ive searched around and have seen some of the part numbers with a CAP in their number, but then again some have also had CAR in the part number.
    Which is the correct main board that should be associated with my e701ia3?
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Vizio E701Ia3 main board question (pics attached)
    According to shopjimmy that board is for your tv.
    • T3xasa22a22in
      • May 2016
      • 11
      • Usa
      I saw one for an Lftrnxap model and iirc, it was not the same. Also i spoke with a local tv repair shop, and they said the model number printed on the mb should match the model printed on the tv. Vizio replied similarly. Just wanting to rule out all possibilities that it is the drivers on the bottom of the panel in which need removal.
      • miyagi
        • Apr 2014
        • 6
        • usa
        I have same tv e701ia3 with blue screen. When menu is hit you can see a change in brightness but no menu. Have been told it was t-con but have tried 4 different t-con boards, nothing changed. After some investigating found pin one of IC ( FP6145B ) U102 erratic. Broke IC trying to lift pin to isolate. Anybody know of a substitute IC.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          http://www.datasheetframe.com/PDF/FP6145B-PDF/870666
          Ali Express
          https://www.aliexpress.com/wholesale...chText=fp6145b
          • miyagi
            • Apr 2014
            • 6
            • usa
            Thanks that's the company I tried ordering from but never got a reply. I found the data from a different source. I'm going to try locating FP6368. I hope it works, I know a few repair shops that have same tv with same problem.
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • gavric
              Vizio M70-C3 Half picture is bad, main board on its last leg?
              by gavric
              Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
              When tv powers on vizio V logo shows nice on whole screen. picture 1
              When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
              When i start youtube picture shows on left side fine, right is all scrambled. pic 2
              When i click video to start playing picture goes black(like when you change...
              09-02-2021, 08:55 PM
            • fharris1977
              Vizio D50u-D1 Dead: PSU or Main Board?
              by fharris1977
              Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
              03-12-2024, 12:22 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
