Toshiba 24d1434db / Vestal 17IPS61-3 help
  • dooosuk
    • May 2016
    • 24
    • United Kingdom
    I'm new to this so please bear with me. I've been reading plenty of threads and so I'm hoping I've tracked down my issue.
    My toshiba 24d1434db has no power, not even the standby led.
    The capacitors all look OK and there doesn't appear to be an obvious blown component from looking at the board.
    I've found threads for the Vestal boards which appear to indicate faulty diodes may be the issue.
    I've tested with a multimeter and get the following readings:
    D8 - no diode fitted
    D9 (UF5402) - 0500 and 1000 when poles reversed
    D10 (SB5B0) - 0030 and 0050 when poles reversed
    D11 - no diode fitted
    D12 (SB5B0) - 0030 and 0050 when poles reversed
    D25 (SB5B0) - 0030 and 0050 when poles reversed
    So I understand it's likely to be only one of the SB5B0 diodes but I'm best replacing them all. Can I fit a better diode? Any suggestions?
    Should I replace the UF5402 diode as well or is that reading all ok and best left as is?
    Can I fit extra diodes in D11 and D8 without any issues? (On one thread someone appeared to do this). Would this reduce the chance of a future re-occurrence as well as using thermal epoxy?
    Thanks, your help is appreciated.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Toshiba 24d1434db / Vestal 17IPS61-3 help
    with diodes if im not sure i always unsolder and lift one side off the board and retest that way sometimes you can see if diodes are leaky too.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Checked if you have a voltage on the other side of the diodes ?
      • dooosuk
        • May 2016
        • 24
        • United Kingdom
        I thought I'd read the voltages on both sides and listed them above. Will re-check with my multi-meter later but sounds like I probably need to unsolder one side first.
        • dooosuk
          • May 2016
          • 24
          • United Kingdom
          Right, so I've de-soldered the diodes and taken the readings again
          D9 (UF5402) - 0500 and OL when poles reversed
          D10 (SB5B0) - dodgy
          D12 (SB5B0) - 0300 and OL when poles reversed
          D25 (SB5B0) - 0300 and OL when poles reversed
          So, my original questions still stand
          I'll replace all the SB5B0 diodes but is there a better diode I can fit? Any suggestions?
          • vinceroger69
            • Mar 2012
            • 6714
            tom66 in another thread recomends these
            http://www.ebay.co.uk/itm/UF5408-Rec...item25789d54dd
            https://www.badcaps.net/forum/showthread.php?t=41922
            But if it was my set i would replace like for like with the diodes but i would change all of them in one go
              Those, or MUR460 / HER308G.
              Needs to be a fast diode, so 1N5408 is no good. UF5408 is a fast type.
              • vinceroger69
                • Mar 2012
                • 6714
                is there a upgrade for the SB5B0 diodes tom
                • dooosuk
                  • May 2016
                  • 24
                  • United Kingdom
                  Just to clear up some of the information above, are we saying:
                  Replace the UF5402 with a UF5408
                  Replace the SB5B0 with a SB5100 or similar (from this post https://www.badcaps.net/forum/showpo...5&postcount=48)
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    http://www.ebay.co.uk/itm/1722173855...%3AMEBIDX%3AIT
                    http://www.ebay.co.uk/itm/1717147546...%3AMEBIDX%3AIT
                    these are what i have just ordered as i have a set here needing the diodes changed.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Cheers bud
                      • dooosuk
                        • May 2016
                        • 24
                        • United Kingdom
                        All fixed with the new SB5100's.
                        Thanks chaps
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Nice one
                          • GnobarEl
                            • Feb 2020
                            • 17
                            • Portugal
                            Nice! Well done!
                            • technicalspecialist
                              Vintage fan repair, copper wire question
                              by technicalspecialist
                              I currently have a customer's vintage fan on the work bench to repair.
                              It uses an induction motor with 4 poles. One of the poles is open.
                              I couldn't find the break so i cut off the original wire.
                              I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                              I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                              The enamelled copper...
                              03-16-2023, 12:54 PM
                            • Dan81
                              Two different poles - two machines
                              by Dan81
                              Thought I might share them with you. One's retro, the other is somewhere inbetween "poles".
                              1:
                              Delux MT375 case
                              JNC LC-B350ATX PSU - recapped with good caps and with completed filtering
                              Jetway J-7BXAN Rev2.1
                              Pentium 3 450MHz/512KB/100FSB - SL35D, Slot 1
                              Hitachi-LG DVD-RW, PATA
                              Seagate ST310211A 10GB
                              3dfx Voodoo 3 3000 16MB TV-Out AGP 2x
                              NEC PCI USB card
                              Yamaha YMF-719 soundcard
                              256MB RAM PC133
                              Windows 98 SE 4.10.2222A w/ NUSB3.3
                              Realtek RTL8139C PCI Ethernet car...
                              09-04-2018, 11:02 AM
                            • Gust zhang
                              Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                              by Gust zhang
                              ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                              02-16-2025, 08:39 AM
                            • handsworth
                              Samsung UN65NU8000F No Picture
                              by handsworth
                              Picked this tv up off the curb in excellent condition but its in reboot loop. Im not a tech so I dont understand all the technical talk. I have done all the common things like disconnecting the main cable and the lights stay on. Removing lvds cables one at a time produces nothing but the constant reboot loop. I would like to try the jumper thing but can someone show me exactly which two poles to jumper? TIA
                              07-31-2024, 09:39 PM
                            • totto210
                              lenovo legion 5 15-lmh05 nm-c911 charger problems
                              by totto210
                              Hi guys, well the summary is this:
                              the equipment arrived because it did not turn on (it had been the original 230w source the problem) then I feed with my regulated source and without wanting to invert the poles. the equipment turned on and turned off.
                              This damaged the charger and its mosfets both high and low switching.
                              It also damaged the input mosfet (pq102).
                              by chance i had another lenovo legion just like this one and i removed the components and tried to turn it on and it turned on but ....... it burned again the high and low mosfets and switch (pq104, pq105, pq103)....
                              05-23-2024, 10:03 AM
