Panasonic TC-P46X3 - HDMI went out
  • jason123
    • Oct 2015
    • 1083
    Hi there, I have a TC-P46X3. It works fine, except that the HDMI Port 1 is not recognizing anything connected to it (tv says check signal...). I had the board professionally serviced and they ran the processor through reflow. That didn't help.
    What components could have gone bad between the connector and the processor? (of course it could be the processor also maybe) I'm unable to find
    a schematic for that board.
    Any help is appreciated. Main board is TNPH0911AY, and I did software update, and TV reset. Board doesn't seem to be available anywhere for purchase, so I'm doing component level troubleshooting. Thank you in advance!
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P46X3 - HDMI went out
    Is it just hdmi1 or all hdmi? There a hdmi controller chip and they do get taken out by lightning easily. .
    Pts electronics inc would be a good
    Place for a rebuild
    • jason123
      • Oct 2015
      • 1083
      Thanks, yes, only HDMI 1 is not working at all.. HDMI2 is touchy - sometimes works, sometimes doesn't.. do you know the part number or anything about the HDMI controller so I can test / replace? I'm ok with electronics.. but tracing the HDMI lines, they appear to all go to the Panasonic MN2WS0177 controller. and you are correct, these failed or started acting up after a storm took out my cable box
      • Diah
        • Feb 2013
        • 6435
        you went so early to reflow the processor ... did you tried reset the TV to factory setting ? as you have only HDMI 1 fault...!!!
        • jason123
          • Oct 2015
          • 1083
          Yes on both counts.. I was sure it was BGA solder related issue.. I was wrong. The reflow went well so I don't think I caused damage, only money, right!
          I did reset the TV to factory .. didn't do it wither.
          • tw2005
            • Oct 2011
            • 6458
            I could be wrong as i don't have schematic in front of me. Never tried fault finding hdmi before. Maybe find a similar board from a different size x3 and convert it to your size
            • tw2005
              • Oct 2011
              • 6458
              does appear the main chip is everything. If you were desparate there is a board onSJ that would work but you'd be going backwards. you'd lose the ethernet and USB ports.
              You'd have to look up the specs of a TC-P4632C in case there's other features lost.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
                After all of...
                07-13-2024, 08:14 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
              • aliougm
                Marantz SR4003 AVR HDMI board issue, seeking for help
                by aliougm
                I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                Connection as below:
                Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                If I bypassed AVR then HDTV screen color be good.
                I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                I replaced all...
                04-30-2022, 12:21 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
