Sharp LC-32SB24U won't turn on
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Sharp LC-32SB24U won't turn on
    It's 217.5 nf. Is that nano? Would that equate to 0.218 uf?
    Looked it up and yes it is. So the cap is ok or is that too low?
      That value is close enough.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Ok. Thanks.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          I know it's not they way you pros like to fix things but a known working used board fixed the tv.
          Thanks helping me narrow it down to which board it was.
          • thetonywarren
            Sharp 4P-B43EJ2U wont turn on
            by thetonywarren
            Sharp TV/Display, wont turn on. Brand new, used for maybe 30 minutes. Possibly heard pop then set went dead. I took a look at the boards, no visual damage to boards. The led power indicator is ON, remote will not turn on. I verified that backlights do come on when powered with separate power supply/LED tester. I also...
            10-01-2025, 09:30 AM
          • JunkmanJimbo
            Sharp lc-55p6000u won't turn on
            by JunkmanJimbo
            Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
            09-28-2024, 12:56 PM
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • Egidio85
            SHARP LC-40LE814E does not turn on 2 flashes
            by Egidio85
            hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
            the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
            reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
            now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
            to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
            07-21-2023, 11:49 AM
          • Mitike
            SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
            by Mitike
            Hello guys,
            I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
            According to other sharp SM-s it is lamp error (I can't find SM for this model)
            And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
            If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
            02-16-2020, 08:11 PM
